AC middle vents
Old May 31, 2001 | 11:10 PM
blee89xj's Avatar
I just bought my 98 Maxima a couple of weeks ago, recently I noticed that the driver side middle vent blows a lot less air than the passenger side middle vent. What i basically want to know is if this is normal, and there's nothing I can do, or should I bring it in to have it looked at since it might be covered under warranty. Any advice or info you give will be appreciated. Thanks.
Old May 31, 2001 | 11:32 PM
Kashoggio's Avatar
the vents where the radio is?
Old May 31, 2001 | 11:58 PM
Justin95SE's Avatar
thats weird
i may be wrong, havent opened it up in a while but i do believe both vents get their air from the same hose/outlet whatever its called, so there really shouldnt be much difference. you might try pulling the vents out and checking for an obstruction, which would be weird. somebody correct me if i am wrong. Oh yah, if you try pulling out those vents, be careful. they break easy
Old Jun 1, 2001 | 12:20 AM
blee89xj's Avatar
i have a bose system if that matters, and yes, there the ones directly above them. there's two of them. the one on the left seems to blow less air than the one on the right. i figure since i have a warranty on the car, why should i risk damaging anything for now. i do have a $50 deductible but i've also been meaning to replace on a new transmitter that came broken with the car also. so i take it it's not normal?
Old Jun 1, 2001 | 06:48 AM
GTNUKE's Avatar
I thought I had noticed this on my '96 SE, but I was never quite sure if it was my imagination. It has always seemed like the right (pass side) vent blows stronger than the left (driver side) vent. Has anyone else noticed this???
Old Jun 1, 2001 | 11:52 AM
JdawgX's Avatar
My 97 SE seems to blow stronger in the middle vents too. The drivers side vent isn't very strong even at full blast. Two of my friends with Max's have the same prob. so i think it's fairly normal.
Old Jun 1, 2001 | 01:08 PM
blee89xj's Avatar
Well actually i'm referring to the driver side middle vent, the right driver side vent blows just fine. so does all the rest except for the middle vent closest to the driver.
Old Jun 1, 2001 | 01:28 PM
BlkCat
On our last hot spell I found both center vents to be even in strength.
Old Jun 1, 2001 | 02:41 PM
jiaxima96's Avatar
I just tested my 96 GXE vents on the way home. I turned the middle left vent towards myself, and middle right vent towards the passenger side, such that the air blowing angle between the two vents is about 90 degree. A/C was on and at its maximum, and the fan speed was at highest.
My right hand moved around back and forth in front of the vents. I could not tell the difference, neither in air blowing speed, nor the coldness.
DJLAX152
May 4, 2021 11:46 AM
Miket2006
Mar 1, 2021 03:55 AM
t6378tp
Sep 29, 2018 04:27 PM
gigabyte
Jan 6, 2017 06:05 PM
spidgeon
Sep 9, 2015 03:36 PM
