Loose Trunk Hinge
Old Oct 30, 2005 | 05:21 PM
PoePoe2797's Avatar
Loose Trunk Hinge
I noticed that on my car, the trunk seems to be kinda loose. On my dad's maxima, the trunk is solid when closed, but on mine there is a little play when I push down when it's closed. It also chatters a lot on the highway and over bumps. I can hear it and see it bounce a little in my rear view mirror. Is there any way to tighten the hinge a little?
Old Oct 30, 2005 | 06:56 PM
rocco5446's Avatar
Is your trunk latch loose? Then you'll need to tighten it. If not...
There should be a round rubber piece on each side of the trunk along the edge that the lid rests against. If these are missing, then you'll need to get a new set. These help keep the lid from moving around. If you have these then...
Push down on the lid near the corner and if it moves, you'll need to lower the position of the trunk latch. There are two screws holding it in position.
REDinLV
Aug 15, 2024 12:30 AM
D Mason
Jun 21, 2016 04:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
