Those with 5th gen clutch in 4th gen, I have a question
Old Nov 3, 2005 | 08:10 AM
cardana24's Avatar
Blown
What parts did you buy? I was under the impression that I could get all fifth gen (00-01) parts and it would bolt right up to my 95GXE. I am planning on ordering a fifth gen: Pressure Plate, Clutch Disc, Throw Out bearing, and pilot bushing. Is this correct? I have heard mixed thoughts, but I would like to hear from the people who actually put one of these in there fourth gen. Thanks for your help.
-Carson
Old Nov 3, 2005 | 08:17 AM
Stabone's Avatar
-Carson
i put a 5th gen on my 97 and I bought the 5th gen clutch, PP, and TB. So far the setup is great, it all bolts up perfectly, plus I believe it is cheaper than the 4th gen setup. go for it!
Old Nov 3, 2005 | 08:28 AM
MrEous's Avatar
^ Jeff™
I plan on doing this if/when it needs replacement. I'm at 90k and the original stock is still holding strong.
Old Nov 3, 2005 | 08:53 AM
joosdawg's Avatar
the best setup ive seen and have is...
throw out bearing(5th gen) 30502-41U20
Clutch disc (3rd gen,is thicker and bigger thus lasts longer) C0100-6E600
Pressure plate or Clutch cover(5th gen) 30210-89F00
I also assisted Eckohb in installing this same setup in his 95 and boy does it grip hard! Ive never really heard of anyone else using that part # for the disc but i would highly recomend it.
-Ryan
Old Nov 3, 2005 | 09:30 AM
cardana24's Avatar
Blown
Thanks for the advice guys....
Joosdog, was there any modification needed to fit the 3rd gen clutch disc?
Old Nov 3, 2005 | 09:32 AM
joosdawg's Avatar
nope fits perfectly under the pressure plate almost like its made specifically for 4th gen use with 5th gen pp lol.
Old Nov 3, 2005 | 09:45 AM
cardana24's Avatar
Blown
ok next question. which year third gen? VG or VE car?
Old Nov 3, 2005 | 10:13 AM
BigLou93SE's Avatar
I've heard you don't need the pilot bushing, but I may be wrong. I bought the 5th gen. early model Pressure Plate, 5th gen. Clutch Disk, and 5th gen. Throwout bearing. Those 3 (or four parts if the pilot bushing is actually necessary for the install) is all you need. Cool idea with the 3rd gen disk though!
Old Nov 3, 2005 | 10:33 AM
cardana24's Avatar
Blown
why would you not need the pilot bushing? Do they not wear out?
Old Nov 3, 2005 | 11:00 AM
BigLou93SE's Avatar
IIRC, when I was researching my clutch swap right around the time that JSutter was first installing his, I was not told to get a pilot bushing. Later on, I remember reading why it was not needed, but can't remember the explaination. I replaced the pressure plate, disk, and throwout bearing when I had my clutch replaced.
Old Nov 3, 2005 | 11:42 AM
MrEous's Avatar
^ Jeff™
-Ryan
Thank you, Ryan, for the part #s.
Old Nov 3, 2005 | 12:39 PM
SPiG's Avatar
SomePsychoGuy
That is the same part # I have seen for the 5th gen disc.
http://forums.maxima.org/showpost.ph...3&postcount=33
Old Nov 3, 2005 | 03:21 PM
joosdawg's Avatar
well i ordered it as being a 3rd gen disc, if you look up the part # on jrnissanparts.com it says: Nissan Maxima 1989-1994 All applications news to me if it is the actual 5th gen clutch disc but i understood it to be the 3rd.
Old Nov 3, 2005 | 05:16 PM
THT's Avatar
THT
Throbbing member
You don't need the pilot bushing at all. I've been running without one for over 5K. Why? I don't know...ask BlackBIRDVQ.
Old Nov 4, 2005 | 05:44 AM
cardana24's Avatar
Blown
It's only like a five dollar part at the dealership, I don't know what it is for. Could anyone explain what it does and why you would or would not need one.
Old Nov 4, 2005 | 05:47 AM
BigLou93SE's Avatar
I'd say pm BlackBIRDVQ, becuase I really don't know what it's for and why I didn't have to replace it. I was just told to buy the three parts said above, and that was it.
Old Nov 4, 2005 | 09:17 AM
joosdawg's Avatar
i also never replaced that didnt replace the axle seals either.
Old Dec 14, 2005 | 07:49 AM
spirilis's Avatar
If I've read correctly, the pilot bushing is in there but it *doesn't get used at all*. The transaxle input shaft doesn't have any sort of end on it that fits inside. So much for that
Finkle
Sep 27, 2015 09:53 PM
ef9
Aug 27, 2015 07:21 AM
carlosvq30
Aug 17, 2015 11:32 AM
maxima-junky
Aug 13, 2015 09:59 AM
MikesChevelle
Aug 10, 2015 10:53 AM
