removing stock muffler tip
Old Nov 6, 2005 | 11:52 AM
MystA RavE's Avatar
how can I remove the stock muffler tip its on there pretty tight
Old Nov 6, 2005 | 12:01 PM
RastaManMax's Avatar
Spray some grease in there and pull hard. Should slide off after a while. If you're not going to reuse it, just cut it off.
LEMAR
Old Nov 6, 2005 | 12:04 PM
MystA RavE's Avatar
isnt it welded on?
Old Nov 6, 2005 | 12:05 PM
Originally Posted by MystA RavE
isnt it welded on?
Mine wasn't. Budget just pulled it off and handed it to me.
LEMAR
Old Nov 6, 2005 | 03:06 PM
DennisMik's Avatar
the tip is being held on by rust and/or corrosion. use some penetrating oil like 3-in-1 or auto tranny oil. let it soak in and see if it will come off. you may have to repeat if the corrosion is bad.
Old Nov 6, 2005 | 06:44 PM
MystA RavE's Avatar
thanks it worked
Old Nov 6, 2005 | 06:57 PM
Black Maxima
I used two screw drivers and pried the shyt off.
Old Nov 6, 2005 | 07:54 PM
descent's Avatar
i also need to pull my stock cap off and put it on my new pipe because when i bought the car i had to get a new muffler to pass inspection. the shop didnt feel like pulling it off so they just cut it. How can i get it to stay on my new pipe?
The Frye
Sep 2, 2021 11:03 AM
bumpypickle
Sep 20, 2015 08:22 AM
dcam0326
Sep 18, 2015 04:52 PM
TheMafia
Sep 4, 2015 08:26 AM
Justin Kroll
Sep 2, 2015 11:06 AM
