Head Lights
Old Nov 7, 2005 | 06:45 PM
culejoe's Avatar
Head Lights
OK so im sick of these dim POS stock head lights.. i want some bright lights that fit stock housing... im lazy and i dont want to have to do cinversion kits and that whole thing and farly cheap... and Legal i live in cali and cops pull you over for going 46 ina 45 they have nothing better to do sooo some input would be greatly appriciated thanks guys!
Old Nov 7, 2005 | 06:49 PM
Tatanko's Avatar
Bacon Lover
You have many options:
-HIDs (standard or projector retrofit)
-9007 conversion
-OR...you can go the route I'm going (upgraded headlight harnesses and overwattage bulbs).
The route I'm going is fairly cheap. It cost me just over $50, including shipping, for the harnesses and bulbs (from various sources). I installed the harnesses earlier tonight and even that made a small little difference. The real test is when I get the overwattage bulbs tommorrow (80/100w...as opposed to the stock 45/65w).
Old Nov 7, 2005 | 07:04 PM
njmodi's Avatar
Do I get a tax break?
I would suggest the 3rd option Tatanko mentions - its the safest in terms of being cop-friendly.
The HID kit w/out projectors is just asking for trouble...
Old Nov 7, 2005 | 07:11 PM
culejoe's Avatar
what about the Cefiro swap you think thats worth it?
Old Nov 7, 2005 | 07:15 PM
Tatanko's Avatar
Bacon Lover
In terms of light output? No.
Old Nov 7, 2005 | 07:20 PM
culejoe's Avatar
hmm ok thanks for you help one more here i was looking at http://www.discountheadlight.com found the link on this site and found APC bulbs and one had the description of... : Headlight Bulbs, Replaces 9004 Plasma Super White Xenon, 60/55 Watt, Twin Pack, DOT Approved....... has anyone used them? worth it? thanks again.
Old Nov 7, 2005 | 07:27 PM
Tatanko's Avatar
Bacon Lover
Those bulbs are crap. Honestly, I can't even believe you're considering purchasing an APC product. Anyway...
If you're looking to go the same route as me, use these links:
http://www.cardomain.com/item/EUR9004HXC (bulbs)
http://www.sportcompactonly.com/prod...1161&c=134&l=2 (harnesses)
Mention Maxima.org when you order the harnesses and you'll get a discount. Your total should be something like $52.60 shipped for both items from those 2 stores.
Just going with bulbs isn't going to help anything. Not unless you get overwattage bulbs like I am, in which case you need the upgraded harnesses so you don't fry your stock ones.
Old Nov 7, 2005 | 07:29 PM
culejoe's Avatar
i was just curious just across them ok thanks i will give that a try....
Old Nov 7, 2005 | 07:32 PM
culejoe's Avatar
So install is farly easy with that..... i dont have a whole lot of experience yet but if its pretty straight forward thats awesome.
Old Nov 7, 2005 | 07:33 PM
RA030726's Avatar
I'm nutty for Nissans
if i told you eurolite was a joke, would you belive me?
if i told you over watts are a joke, would you belive me?
if i told you i had ricer blue 80/100 watt 9004 and they were not brighter than stock, would you belive me?
Old Nov 7, 2005 | 07:35 PM
Tatanko's Avatar
Bacon Lover
I installed the harnesses this afternoon in literally less than a minute. Unplug your stock ones, plug the stock ones into the new ones, plug the new ones into the bulb socket.
Those bulbs were extremely cheap. If they're a disappointment, I'll just throw them out. I doubt they'll be ricer blue, either...they're advertised as 3500k.
Old Nov 7, 2005 | 07:58 PM
TurTLe*'s Avatar
yea same thing. actually i was the one who gave you that link tatanko. When i asked about the reviews on those. it was like a total of 20$ if they stink. i'll just throw it on ebay and get some other ones. Most the time i would have stuck with stock. But my light output as of now stinks. So anything is a worth it at this moment.
Old Nov 7, 2005 | 08:15 PM
Tatanko's Avatar
Bacon Lover
Yeah, I remember. This isn't exactly a large or risky investment, so why not try it? As I posted already in this thread, just adding the harnesses alone I noticed a *tiny* bit of an increase in brightness.
Old Nov 7, 2005 | 11:18 PM
MrDicks95SE's Avatar
Offset Is Everything.
just get HIDs and be done with it.
Old Nov 8, 2005 | 10:21 AM
culejoe's Avatar
how hard are HID's to install?
Old Nov 8, 2005 | 03:17 PM
Tatanko's Avatar
Bacon Lover
Ok got the bulbs this evening. They are not any brighter than my Silverstars (comparing both with the upgraded harnesses). I like the color, though, because it's not really all that blue. Mostly white with a tiny, tiny hint of blue. Oh well, I guess. The harnesses were worth it, though, I guess.
Old Nov 8, 2005 | 07:23 PM
99grnmaxgxe's Avatar
Those bulbs from Cardomain aren't DOT approved:
(Note: These bulbs are not DOT approved. They are sold for show car or off-road use only. Check local laws before using.)
So I don't think he wants to take the risk of getting pulled over. I heard that Sylvania Xtra Visions are great at light output.
Old Nov 8, 2005 | 07:36 PM
just grab a plug&play kit and its easy as pie. pretty much youre hooking it up to your stock harness which goes to the ballast/ignitor then to your bulbs. plug it in, strap down the ballast and youll be done in 10 minutes.
Old Nov 8, 2005 | 07:38 PM
xtra visions have more output onto the road than silverstars.
Old Nov 8, 2005 | 07:51 PM
Tatanko's Avatar
Bacon Lover
Overall I'm disappointed with the bulbs I got. May even throw my silverstars back in. It's weird, because when you look at the beam pattern, there is no "cutoff." Rather than like semi-circles for each beam, it's a full circle. So it APPEARS brighter. In all actuality it isn't any brighter, and due to being a little more blue may even be dimmer Looks HID-ish, though, because it's only got a tiny hint of blue (like 4500k maybe).
Needless to say, silverstars and upgraded harnesses are going to have to do until I can get HIDs for Christmas or something
Old Nov 8, 2005 | 08:04 PM
Do you have any pics for us to see what you are talking about?
Old Nov 8, 2005 | 08:14 PM
Tatanko's Avatar
Bacon Lover
I will take some tommorrow evening, as it's already almost 11:30 here and I'm ready for bed.
Old Nov 8, 2005 | 08:39 PM
culejoe's Avatar
hey do any of you happen to have a good site to but it from thats farily cheap/good priced.. thanks for all your input its much appriciated... i live out side of sac in a town called Folsom and lots of the roads are just black and these lights just are not cutting it... thanks again for all the help.....
Old Nov 9, 2005 | 07:43 AM
Tatanko's Avatar
Bacon Lover
You mean for an HID setup? There are some going for as cheap as $260 shipped right now as part of a group deal. Check the Group Deal/Sponsors forum.
Old Nov 9, 2005 | 04:08 PM
Tatanko's Avatar
Bacon Lover
Ok, finally got pics tonight of what it looks like. Not the greatest quality, but here you go:
Notice how the left headlight is more of a circle than a semi-circle. With both Eurolites in, the right one does the same thing. That picture shows Eurolite on the left, silverstar on the right.
Old Nov 9, 2005 | 06:28 PM
RA030726's Avatar
wow, way to make a crappy beam pattern worse!
does the bulb have a painted tip?
Old Nov 9, 2005 | 07:02 PM
Tatanko's Avatar
Bacon Lover
Honestly, I can't remember. I'll have to look. As far as the beam pattern, yeah...it sucks. I'm switching back to the silverstars when I get time. I have to admit, I like the looks of the bulbs...but it's not worth the worsening of my light output. Leaving the harnesses installed, though, they actually helped a little.
HID's in a month or two for me...I need to do what I should have done in the first place, but didn't have money for.
Old Nov 9, 2005 | 08:02 PM
culejoe's Avatar
yea ima go for the HID's 6000k whenever i can afford it...... i would like to get the projecters and angle eyes but i have no idea what im looking for or even how to install it.... the peopel on the forum that do that stuff like on the other side of the country and i dont want to pay $$$$$$$$$ to get it installed.
Old Nov 9, 2005 | 09:07 PM
NYC32798's Avatar
I remember a while back seeing projector headlights for the 4th gen max. I lost the site though. They may possibly be a better alternative to stock. Speaking of those does anyone know what I'm talking about and possibly have a link to that site?
Old Nov 9, 2005 | 10:03 PM
KNYFE's Avatar
I've got PIAA bulbs in Cefiros... I think that -
1. Cefiros are brighter then stock
2. Bulbs make a huge difference.
I bought some knockoff "Like Silverstar" bulbs. They were brighter then stock. Then bought Silverstars for my fog lights that made my headlights look yellow. Then bought the PIAA bulbs that do the same to my Silverstars. Conclusion - If you want to do a cheap upgrade, by better bulbs. Huge difference.
Old Nov 10, 2005 | 08:34 AM
Yeah you're right, the beam pattern sux but it looks pretty cool how they are a bluish white color.
Old Nov 10, 2005 | 01:48 PM
RA030726's Avatar
OEM cefiros have a pretty good beam pattern due to the H4 bulbs.... the best halogen bulb out there really. the smoked aftermarket ones however are garbage.
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
dcardello
Sep 3, 2015 11:44 PM
