Need new rotors
Old Nov 10, 2005 | 10:06 AM
Momaxima's Avatar
Need new rotors
Hey,
looks like I need two new rotors, want to buy larger rotors if possible, what would you guys suggest? I'm on ssr integral A2s 17x7 (+38mm offset i believe). I don't want to add spacers if possible. I also wanted to know if installation is different between front and rear rotors.
Old Nov 10, 2005 | 10:08 AM
NmexMAX's Avatar
dot dot dot ...
Matts kit is good.
Blehmco
Old Nov 10, 2005 | 10:13 AM
Iron Scimitar's Avatar
Tha Snatcher
Larger rotors wont make a difference not unless you have a BBK. I'd recommend getting stainless steel brake lines and some good front pads (if you dont have them already). People are gonna say, "Get drilled and slotted rotors, blah blah blah", but for daily driving get some Brembo rotors and some good pads with SS lines.
There are lots of group deals going on in the GD section. BrianV can get you some SS lines for a great price. Send him a PM or visit his thread in the Group Deals section. Auto_Max has tons of brake equipment for sale as well. Hope this helps.
Old Nov 10, 2005 | 10:49 AM
Dubbya's Avatar
VK56 Inside
If it was me, I would stay with OEM pads. High preformance pads are made to bite and bite good. This is great for the track, but hell on your rotors. I used Axxis Ultimates and by the time I needed to change the pads the rotors had nasty grooves the size of the pad in them. Basically the pads ate up the rotor very quickly.
Old Nov 14, 2005 | 07:10 AM
SkiDaddy's Avatar
If you stay w/stock size rotors Autozone has decent ones, make sure you don't get the cheapest ones they sell. I looked at them side by side w/the slightky more expensive ones & you can see a much better grinding pattern on the better ones.
Old Nov 14, 2005 | 08:47 AM
MaximaSE96's Avatar
Maxima Owner
i would personally use Brembo blanks..with hawk hp pads...and some SS lines. but my car sees heavy auto-x abuse in the summer........but when it al lcomes down to it u arnt gonna stop if ur tires loose traction while braking so also keep that in mind
Old Nov 14, 2005 | 07:11 PM
Sharp's Avatar
Duralast or Valucraft? I am about to do a brake job myself
Old Nov 15, 2005 | 06:09 PM
SRJesse's Avatar
This has been talked about a lot and really depends on your driving habits, where you drive, what you want your breaking ability to be like, etc.... Brembo blanks and OEM pads have been said to be the best combo unless you absolutely need more braking power say if you are racing for real, or have some serious power under the hood...
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
