Difference b/w Walker & Bosch O2 sensor
Old Nov 18, 2005 | 11:12 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
I'm looking to replace an O2 sensor (SES on). any diff. b/w the Walker and Bosch brands other than price?
Old Nov 18, 2005 | 11:29 AM
the_3d_man's Avatar
as far as I know Bosche is OEM and I doubt the others are any different...
Old Nov 18, 2005 | 11:32 AM
C MAX's Avatar
i,ve used walker before and my brother has them now with no problems.
Old Nov 18, 2005 | 11:58 AM
Taken2DaMax's Avatar
Sorry to kinda go off topic but is there any difference in changing the O2 sensors on the 97-99 models than if you were to do it on 95-96?
The How-to-do-it only have the 95-96 instructions...
Old Nov 18, 2005 | 12:07 PM
C MAX's Avatar
nope its the same as simple as changing a spark plug. unless its cali or fed spec they are all located in the same place
Old Nov 18, 2005 | 12:17 PM
4evamax's Avatar
I never heard of the walker oxygen sensor, is it less money? I just changed mine and the bosch was what my mechanic told me to use. Just thought its allways better to go with oem.
Old Nov 18, 2005 | 12:19 PM
RA030726's Avatar
I'm nutty for Nissans
the rear o2 is in a slightly differnt place and its a different part number.
Old Nov 18, 2005 | 12:22 PM
C MAX's Avatar
the left and right bank sensors are the same part one is located in the front by the radiator and the other by the passenger side, if you take off the wheel you will see it, the only one that is different is the one after the cat.
Old Nov 18, 2005 | 01:48 PM
RA030726's Avatar
exactly. also the 2 front sensors are actually the same, but the wires are a different length. i have swapped them around with no problems.
Old Nov 18, 2005 | 06:37 PM
the_3d_man's Avatar
So is it safe to say theres no problem with going with Walker instead of Bosch?
Old Nov 18, 2005 | 07:02 PM
FishyMan's Avatar
many have gone w/ walker. no probs...
Old Nov 18, 2005 | 07:49 PM
PLUMMAXSE's Avatar
I changed all three of mine to Walker. No problems. They just cost a little less!!
Old Nov 19, 2005 | 08:46 AM
C MAX's Avatar
oh yeh man your right, the only difference is the length of wire
Old Nov 19, 2005 | 10:45 AM
tomservo291's Avatar
ok, i gotta do mine too.
0707 is "Rear heated O2 Sensor," and from what I gather this is the *more expensive* one downstream of the cat, right? Don't want to go and make a stupid mistake like getting the wrong type here.
Old Nov 19, 2005 | 03:14 PM
C MAX's Avatar
thats it theres only one rear so your safe. the other 2 are front heated left and right bank
Old Nov 19, 2005 | 07:12 PM
FishyMan's Avatar
miens threw a code 2-3 times arleady. my latest one which iresetted showed NO Errors. someimtes it shows 0707, sometimes it shows the NO ERROR cel. i really d k what's up. it can't hurt to change.
i have 70k on mines, currently for 2 weeks w/ the car reset im not getting that code no more.
Old Nov 20, 2005 | 05:21 AM
C MAX's Avatar
that means its on its way out, from what i gather the rear sensor is a back up for the 2 front so thats why its probably intermitting. if it keeps coming on i would just change it and call it a day.
bbsitum
Sep 6, 2019 07:31 PM
ac max 92
Sep 17, 2015 07:35 AM
Djsmaxima
Sep 14, 2015 11:58 PM
