O2 Sensor Question
O2 Sensor Question
Has anyone ever tried to by-pass the o2 sensors? Im talking about using a transistor or resistor in the sensor hole just like the ks mod? just wondering, two of mine are out. Kinna expensive for the real thing, and I wouldnt mind getting the extra mpg.
Wont work . You could install a simulator instead to substitute the REAR only o2 sensor. They run at $30, instead of the $60 sensor. It's not a big saving, but keep in mind simulators are meant for off road (track) use.
Originally Posted by Ninos_Maxima
two of mine are out...... and I wouldnt mind getting the extra mpg.
www.oxygensensors.com
ill try both ways, the ghetto way first, the one i was talking about... Ill report to you guys if i "FEEL ANY GAINS" but i am going to replace them this friday or saterday
This is a really, really bad idea. In closed loop operation (which is most of the time), the ecu relies on O2 sensor information to determine how much fuel to provide the engine through the injectors. If you simulate a signal that has nothing to do with the actual afr, the ecu will either provide more fuel or less fuel than the engine needs, depending on what voltage the ecu sees. You can end up doing damage to your engine that will exceed the cost of buying new sensors.
you can still pass emission... as long as the main cat is doing it's job. Typically the emissions passes, but they pull an trouble code. The o2 Sensor simulator takes care of the trouble code. If you have a bad main cat, you will still fail emissions.
It's probably not the sensor that is bad... if the precats are gone, then the 2ndary O2 sensors are working correctly, and causing the ECU to set off the trouble code. I am not sure how long the sim is expected to work for... I have only had mine in for a week.
sdotcarter
Sep 2, 2015 09:53 PM
