HELP!! MY TRUNK WON"T OPEN!!!!
Old Nov 19, 2005 | 07:25 PM
sniper615's Avatar
like the title says my trunk won't open with the key or pulling the lever by the seat(i have one of the originals 95 maximas with the lever by the gas buttom)
what can i do....help help...
thx in advance
Old Nov 19, 2005 | 07:56 PM
DennisMik's Avatar
look in the trunk thru the back seat. there is a lever next to the lid latching hook (on the bottom part, not the trunk lid) it looks like a little tab of metal. this lever should be all the way up. when it is down the trunk cannot be opened with the release lever or the remote. the trunk should open with the key, though. maybe the lever is somewhere in between top and bottom.
if moving the lever up and down a few times doesn't help, then try loosening the two bolts next to the little lever and see if the extra "play" will let you open the trunk.
if that doesn't work, take the bolts all the way out and see if you can get the trunk open.
Old Nov 19, 2005 | 08:05 PM
brooklynK3Y
Fiddle with the key in the trunk keyhole.
Old Nov 19, 2005 | 08:40 PM
the_3d_man's Avatar
and there is also something in the stickies FAQ I believe... I swear i saw it there before...
Old Nov 20, 2005 | 06:03 AM
Armelius's Avatar
without crawling through your trunk you need to find a large pole and lift up on the brass looking lever. After you get it open you might want to check the lock and see if it disconnected from the turning mechanism.
Old Nov 20, 2005 | 06:58 AM
GStrength's Avatar
Or just use a crow bar and pry it open, then fix the problem...
Old Nov 20, 2005 | 07:24 AM
s0ber's Avatar
As long as you paint for the paint damage...
Old Nov 20, 2005 | 07:32 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Originally Posted by joosdawg
the "Trunk Sniper" ... anyways
How is that funny?
Old Nov 20, 2005 | 11:45 AM
Maxima lover
Well for some reason my key has never worked on the trunk, so one day when I was closing the trunk, one of my friends pressed the open button fro the trunk on my door and it locked it. We tried everything to get it open before I had a 14yo who lived by me somehow crawl through the little opening in the back seat and move the switch to open it. After I looked at it, you can reach it with some type of poll or stick. I would suggest looking at some pictures of how the lock looks and then just go at it. Good luck.
BTW did you key ever work with the lock?
Old Nov 20, 2005 | 12:00 PM
devilz05's Avatar
Shift_3.0
Very strange, I just bought my max and the key doesnt work on the trunk either. You have to do it from the inside or on the remote...hmmmmm
Old Nov 20, 2005 | 06:57 PM
sniper615's Avatar
thx for everything guys, i fixed it after all
Old Nov 20, 2005 | 07:00 PM
keb1209's Avatar
I've never been able to use my keys to open my trunk either, has to be w/ the remote or from the inside.
REDinLV
Aug 15, 2024 12:30 AM
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
mrgooch
Sep 21, 2015 08:43 PM
