clutch problem
Old Nov 21, 2005 | 01:51 PM
lxl - MaX's Avatar
clutch problem
im having problems with my ACT clutch that is less than a year old...
when i press in the clutch i have to press it in all the way and also i have to push very hard. i used to not have this problem and i am unsure of what is causing this. i hhave adjusted the pedal all the way and it worked fine for a few days but now i still have to push the pedal all the way in to shift gears. anyone know what could be causing this????
JOn
Old Nov 21, 2005 | 01:59 PM
ewuzh's Avatar
You're supposed to push the clutch all the way in to shift gears...
Check your fluid level. If it's low, fill it up and bleed the hydraulic system.
Old Nov 21, 2005 | 02:14 PM
lxl - MaX's Avatar
what im saying is that i have to push the clutch all the way to the floor before it engages, and ive never heard of any car that does that. the fluid level is fine.
JOn
Old Nov 21, 2005 | 02:59 PM
the_3d_man's Avatar
you mean before it disengages?
I have mine set to engage low so i have to push my clutch in all the way.
but... you're supposed to push the pedal all the way in!
I've heard that shifting without pushing the clutch in puts a lot of stress on the TOB
Old Nov 21, 2005 | 03:03 PM
Nismo3112's Avatar
Custom User Title
Can low tranny fluid level cause rougher shifting? I have about 3.8 qts in the tranny right now.
Old Nov 21, 2005 | 04:30 PM
ThurzNite's Avatar
I thought it was 4.75 qts?
Jae
Old Nov 21, 2005 | 07:09 PM
SPiG's Avatar
SomePsychoGuy
BTW He put a SS clutch line and bled the clutch line before. I am not positive it was a perfect bleed since he has probably had a shop do it and done it himself since then.
Both of us need to check our tranny fluid level. My shifting has gotten kind of rough lately.
Old Nov 21, 2005 | 07:28 PM
MDeezy's Avatar
4.5 is for the manual tranny. I would think less gear oil and old fluid could lead to rougher shifts.
Old Nov 22, 2005 | 11:22 AM
lxl - MaX's Avatar
bump.........
Old Nov 22, 2005 | 12:12 PM
Nismo3112's Avatar
Custom User Title
Well ACT clutches are known to have a hard pedal feel, but you said you used to not have the problem..
Maybe the slave cylinder is starting to get seized
Old Nov 22, 2005 | 06:45 PM
ewuzh's Avatar
JOn
Well, bleed it again anyway. Shouldn't take too long. Just get a buddy to help you.
"If you do not get all of the air out of the system, you clutch will disengage with the clutch pedal closer to the floor. If you think your clutch is "different" than it is, and you must continue bleeding." -Motorvate.ca
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
pears
Sep 18, 2015 05:25 AM
slowlifer
Sep 8, 2015 05:53 AM
