dimming lights
ok i have a question also
Is it normal if your lights are dimmer when at idle (in drive)
than when you hit the gas when beganing to move?
my lights dims when i roll up or down on the windows too, but it is very noticable.. bad battery? bad alt.? what's up?
than when you hit the gas when beganing to move?my lights dims when i roll up or down on the windows too, but it is very noticable.. bad battery? bad alt.? what's up?
my lighrs get a tiny bit brighter when I hit the gas... and they dim a little when i roll the windows down... I'm not too worried about it. I probably need a new battery...
it's old and corroded, but it's been that way since I got the car.
The reason your lights are dimming is because Nissan picked out a weak alternator for the maxima. It has a slow response time to the load caused by the windows rolling up, lights turning on, quick bass notes, etc. The change of current draw brought forth from these operations done in your car result in dimming because of the voltage drop, you can see this on a multimeter (the car should operate at 13.0+ volts while running and 12.5 volts when off). It has nothing to do with you battery as I have dimming when rolling up windows, turn signals flashing, the turning on of headlights, etc. with a red top optima. These are basic functions of a car and there shouldn't be any noticeable dimming. My previous car didn't have any dimming whatsoever even with my aftermarket stereo system with a 70A rated alternator (maxima usually has 110A). With longer extended bass notes I noticed alternator starts to pump in the juice so I'm concluding that it is just the response time.
This is a possible solution but it is very costly, I'm looking to going this route because of all of the other things I want to plug-in to this car...
http://forum.maxima.org/showthread.php?t=438996
Otherwise the dimming you see I wouldn't be worried about it until your brake light and battery light come on while the car is running.
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
