Resetting ecu?
Old Nov 22, 2005 | 11:16 AM
Subzero's Avatar
Resetting ecu?
What is the actual way to reset a ecu after mods? So far ive seen many ways on here, Turn the key on and of so many times, disconnect neg battery cable, turn ecu screw, So what the actual way of doing it?
Old Nov 22, 2005 | 11:27 AM
tavarish's Avatar
fwd gone rwd cr00
The all-knowing stickies hold the answer you are looking for. Go, my son.
Old Nov 22, 2005 | 11:28 AM
njmodi's Avatar
Do I get a tax break?
I'll give you another hint... "ECU Sticky"
Old Nov 22, 2005 | 11:34 AM
Subzero's Avatar
I looked in the ecu section and that just lists the code number and what they mean, where does it say where to reset??
Old Nov 22, 2005 | 11:35 AM
njmodi's Avatar
You need to look harder...
http://forums.maxima.org/showthread.php?t=104931
Old Nov 22, 2005 | 11:39 AM
kormax97
You have to either use a device or using screw driver to turn it but I forget how many seconds and which direction and cr@p... I don't feel like looking in my haynes so you should go buy one or read the stickies.
Disconnecting battery will not reset your ECU, just like how the memory in your USB memory stick doesn't go away after removing it from your computer.
Old Nov 22, 2005 | 11:51 AM
Subzero's Avatar
I must not be getting through here, i don't want to reset my check engine light i want to reset my ecu, where in the stickies tell how to do that?? There is a difference between the engine light and the ecu. Can't someone just tell me instead of referring me to go find it myself when i don't see it there???
Old Nov 22, 2005 | 11:54 AM
njmodi's Avatar
Why do you want to "reset" the ECU? AFAIK, resetting the CEL is the same as resetting the ECU.
Old Nov 22, 2005 | 12:00 PM
Subzero's Avatar
In nissan performance mag they say:
All Nissans have a MAF (Mass Air Flow) monitoring fuel injection system, and they can accept modification to the air intake system with no tuning changes. These types of fuel injection systems measure the amount of air coming into the engine so the engine control computer knows how much fuel to inject for a proper mixture. If the intake system causes more air to be induced, then no problem, the ECU compensates. On our cars, it may help to disconnect the battery for a few minutes to reset the self-learning function of the ECU so the ECU can relearn the new mixture required. It may take a little driving for the engine's ECU to adjust to the intake so you can get all of the power possible out of them. Generally the engine will run better and better for the first 20 or so minutes of engine operation after installing the intake.
Old Nov 22, 2005 | 12:03 PM
njmodi's Avatar
I say resetting the CEL will accomplish the same thing. The ECU is always adjusting it's fuel map... I don't think it has to be "reset" in order to do that.
Old Nov 22, 2005 | 12:39 PM
kormax97
Resetting CEL is same cr@p as resetting ECU. AND, you do NOT have to reset your ECU because like ^ said, ECU is self-learner unlike someone I know.
Old Nov 22, 2005 | 01:49 PM
greengrass215's Avatar
Get a nissan data scan software and the data link connector, from www.blazt.biz, this works for my car......getting code and monitor engine component, and more to it.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
220k+ A32
Sep 22, 2015 03:08 PM
Colossus
Sep 9, 2015 05:46 AM
