Limited range of OEM remote
My OEM keyless entry remote has been acting weirdly sporadically. The range is sometimes so limited that it only works if I press the button while directly on top of the trunk lid, which is currently the case. I thought that my battery was dead initially, so I replaced that and it worked for a while and now this afternoon (after successfully using it in the morning and twice at lunch) it is back to the limited range. What is the common problem, the remote itself or something else? Any help would be greatly appreciated. Thanks.
I'd actually like to know as well, mine works on and off mostly, lately it's been working pretty well, but at times I have to hold down the lock button for a few seconds for it to arm, keep on thinking that I'm gonna set the alarm off accidentally.
Oddly enough, whenever the alarm system doesn't respond to the unlock, lock, or trunk pop commands, the dome light button will always work...
At other times, I've remotely rolled the windows down, then when I get to the car, the doors are still locked.
my other maximas remotes sucked but my current max's is awsome. I live on the second floor of an appt building and my car is parked on the opposite side of the building and i cant see it from here thus theres a whole other appt and half the building in the way of my remote and car. Now this may be far fetched but somehow i hit lock or unlock and i go out to my car to find it in the state that i push the button with. The first time i did it and went out to see it work i was in shock!
-Ryan
-Ryan
^^ he said he did replace the battery. mine was going out and then not working at all, so i replaced the battery and it worked. i agree with cystummax. get a new remote off of ebay and program it and see if it works better.
Originally Posted by 86maxima96
what are you guys talking about? under your chin? what??
Originally Posted by Kevlo911
Put it under your chin and see if it works.
knight_yyz
11-01-2015 01:34 PM
atriuum
09-28-2015 01:19 PM
