New thermostat installed - now car overheats
Old Nov 29, 2005 | 12:58 PM
felix's Avatar
Sittin' On Chrome
I just replaced my thermostat because the car was not warming up. It was stuck open. Now it seems my car overheats. Why would it do this? Thanks for any help.
Old Nov 29, 2005 | 01:03 PM
MrEous's Avatar
^ Jeff™
Just curious but did you use the same 'lb' radiator cap as stock?
Old Nov 29, 2005 | 01:08 PM
Dubbya's Avatar
VK56 Inside
You can check the thermostat you just put in. I think the haynes manual has a proceedure. Basically heat it in water to see if it opens up.
njmodi's Avatar
Do I get a tax break?
Air in the cooling system... you need to purge the air out of the cooling system.
Old Nov 29, 2005 | 01:12 PM
Kevlo911's Avatar
Kevlo for President
On the air in the system.
Old Nov 29, 2005 | 01:23 PM
felix's Avatar
Sittin' On Chrome
How do you do that? I lost my Haynes manual
felix's Avatar
Sittin' On Chrome
Yes, stock cap.
Old Nov 29, 2005 | 01:27 PM
njmodi's Avatar
Take of the radiator cap, just start the car, let it heat up (i.e. thermostat opens), then shut it down, let it cool down... then top of the radiator and reservoir. Do this a few times... if you want to get creative, you can squeeze the lower radiator hose to purge bubbles while the cap is off - be careful of the fans and belts while the car is running.
Old Nov 29, 2005 | 01:38 PM
felix's Avatar
Sittin' On Chrome
How long do you let it heat up and cool down for?
Old Nov 29, 2005 | 01:40 PM
njmodi's Avatar
10 mins for heating, 20 mins of cooling should be enough.. basically you should notice the radiator coolant level get lower - top it off, and repeat the process... keep going until the coolant in the radiator doesn't drop after the car cools down.
Old Nov 29, 2005 | 01:55 PM
felix's Avatar
Sittin' On Chrome
Thanks, I will try that.
Old Jan 20, 2006 | 11:06 AM
felix's Avatar
Sittin' On Chrome
I tried that and it still overheats. I replaced my radiator but no luck. Still overheating. Could it be anything else?
Old Jan 20, 2006 | 11:07 AM
DcMaN's Avatar
water pump ?
Old Jan 20, 2006 | 11:29 AM
MaximaSE96's Avatar
Maxima Owner
prolly air since he has no clue how to bleed the system so he prolyl didnt do it....u can jsut let it run with the cap off for a while...then when it reaches operasting temp turn the heat on to make sure ur getting heat....u will prolly see the coolant gargle or burp while the car is running...usually that gets all the air out
Old Jan 20, 2006 | 11:33 AM
C MAX's Avatar
let it run till it bubbles over, its the ghetto way but it works
Lakersallday24
Jun 16, 2019 01:35 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
Team STILLEN
Aug 10, 2015 04:29 PM
acw
Aug 7, 2015 04:20 PM
