E-brake light on
Old Dec 5, 2005 | 08:01 AM
GoldMax99's Avatar
E-brake light on
Anyone experience this. My E-brake light sometimes stays on after I turn on the car. Sometimes it doesn't, but lately it's been more on than off. And yes, my e-brake is released.
Old Dec 5, 2005 | 08:16 AM
f550maranello2's Avatar
the switch may need to be replaced...
Old Dec 5, 2005 | 08:20 AM
Dubbya's Avatar
VK56 Inside
Check your brake fluid level. You might be a little low.
Old Dec 5, 2005 | 08:46 AM
njmaxseltd's Avatar
If people would read their owners manual........
Old Dec 6, 2005 | 01:52 PM
GoldMax99's Avatar
If people would just post constructive comments....
Dubbya & f550maranello2,
Thanks. I thought it was a sensor, but it makes sense for Nissan to turn this light on for low brake fluid.
Old Dec 7, 2005 | 06:24 AM
a3gus's Avatar
Did you solve the problem???? What was it?
Old Dec 7, 2005 | 11:00 AM
GoldMax99's Avatar
a3gus,
Yes I did solve it. It was low on brake fluid as Dubbya pointed out. It was also in the owner's manual as njmaxseltd was so kind to point out.
Old Dec 7, 2005 | 02:29 PM
RA030726's Avatar
I'm nutty for Nissans
well you need new pads now
Old Dec 7, 2005 | 04:28 PM
Niznos's Avatar
Yes, low brake fluid is a sign of 1. Leak in the brake system/ loss of pressure, or 2. Worn brake pads.
As your pads wear down, the pistons in the calipers displaces the space that used to be occupied by the pads, and so more brake fluid is in the caliper and thus not in the reservoir, and then the brake light comes on from the low fluid. You should have your brake pads checked the first chance you get.
Old Dec 8, 2005 | 02:48 PM
tkd99's Avatar
could be the cable is not releasing all the way
Old Dec 8, 2005 | 02:50 PM
Dubbya's Avatar
VK56 Inside
Dont think that will cause it. There is an electrical connection in the ebrake itsself that triggers the light.
DJLAX152
May 4, 2021 11:46 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
