Cold morning start problems
Old Dec 7, 2005 | 06:16 AM
Siizzzoooo's Avatar
we have a 98 maxima SE with 99k miles.
It just recently started having problems.
Upon firing up the car, it first right up, but the RPMs drop immediately and dies, but sometimes catches itself. Pumping the gas usually fixes the problem.
Not sure, but could it be due to a dirty throttle body?
also, there is a slight humming noise coming from the valve cover, not exactly sure what it is, but it sure isn't normal.
any help would be great guys, I wanted to search first, but the search function wouldn't let me
Old Dec 7, 2005 | 06:18 AM
C MAX's Avatar
i believe its your aiv valve going bad, or whatever the idle control thing is called.
Old Dec 7, 2005 | 06:23 AM
lilaclucymaxima's Avatar
Team Ramrod
The IACV? Clean it.
Old Dec 7, 2005 | 06:24 AM
njmaxseltd's Avatar
Clean your throttle body and the IACV.
Old Dec 7, 2005 | 06:26 AM
Mishmosh's Avatar
Clean your throttle body (if gunked up, the idle air flow is not making it through to sustain idle rpms). 2nd, normally, rpms on a cold car is higher than normal...like 2k rpms. If it is not hitting that initially, consider swapping out the ECTS.
Old Dec 7, 2005 | 08:31 AM
Siizzzoooo's Avatar
alright, well i just got done cleaning the aiv valve and throttle body. they were pretty gunked up.
I started the car, and it idled right around 7-800 rpms perfectly. Gonna run errands with it today, and the real test will be tomorrow morning
thanks guys
tsi6001
Oct 3, 2022 10:23 PM
305head
Aug 26, 2015 09:03 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
