Engine issue!!!! help!
Old Dec 8, 2005 | 07:33 PM
ILLJIM69
someone on a neon board im on posted this question there hoping some nissan people might see it. anyways, i thought i would post it here and see if you guys have any ideas. i said it was prolly a blown maf sensor, but i could be wrong.
"Me and my friend installed his new intake on today and now his car seems really sluggish. His car is a 1996 Nissan Maxima and its blowing out nasty black exhaust fumes. Before his car idled like crap in nuetral, park, reverse and drive, now its like crap in drive and reverse..What could the problem be? Also we just had to charge the battery becuase the car wouldnt start."
thanks guys
jim
Old Dec 8, 2005 | 08:36 PM
Montypup's Avatar
Sounds like a computer or sensor issue.
Old Dec 8, 2005 | 09:06 PM
MDeezy's Avatar
If you guys were cranking a lot then fianlly got it started, that black smoke was a lot of fuel getting burnt off.
If its really sluggish like that, there must be codes. Local auto stores should be able to check them free.
Check Maf with Mutli-meter, as well as cam sensor, and both crank sensors.
checking sparks could tell a lot.
Old Dec 9, 2005 | 07:07 AM
kenscivic's Avatar
did you hook your maf sensor back up??
p.s mdeezy good suggestions
Old Dec 9, 2005 | 07:56 AM
sonicrunch's Avatar
20 bucks says they removed the MAF
Old Dec 9, 2005 | 09:12 AM
ILLJIM69
i will have to ask about that one. thanks guys.
jim
Old Dec 9, 2005 | 01:08 PM
njmaxseltd's Avatar
Is the Check Engine light on? If so, on the top of this page there are instructions for how to pull trouble codes from the ECU.
If it's not on, I'd suspect the MAF sensor is going bad.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Maxima30
Sep 7, 2015 06:13 PM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
