ignition problem ???
Old Dec 18, 2005 | 07:54 PM
Reaction021's Avatar
my car has been having this ignition problem for alittle while it has no crank when i go start the car it has power all the lights work i know the starter is good i think it's one of the relay cause whenever i pull it out and put it back in the car starts fine for 1-2days then back to the same problem do u guy think it's an relay problem or some bad connection any help would be greatly appreciated
Old Dec 18, 2005 | 08:00 PM
matty's Avatar
If its not doing anything when you turn the key, its the ignition switch. About a $30 nissan part or any auto parts store for $25-$40...Very easy to install
-matt
Old Dec 18, 2005 | 08:15 PM
so u don't think it has nothing to do with the relay cause it happen like this last time i replaced the relay and everything worked fine till now i'm assuming my mechanic didn't replace a new one for me
Old Dec 18, 2005 | 11:23 PM
Old Dec 18, 2005 | 11:31 PM
95CustomMaxima's Avatar
-matt
Sounds like an ignition switch to me, common problem on 4th gen's.
-Nick
Old Dec 19, 2005 | 01:16 AM
aajaxx44's Avatar
I am having the same problem. When I turn the key nothing happens, but I can hear sort of a clicking sound. It started about a month ago and I took it to a mechanic and they said it was the battery and the cables that attach to the battery. It started fine for about 3 weeks and then it went back to not doing anything when you turn the key. When I called the mechanic they said that your starter probably went out. Is it really the ignition switch?
Old Dec 19, 2005 | 05:36 PM
LuXXXz's Avatar
i just went thru this problem this weekend
took the starter to autozone and the fuken idiots said it was ok so we put it back on and bought a new battery and still nothing
then i took the starter to murrays because the car wouldnt start still and they told me it was the starter and changed and now it runs perfect
Old Dec 19, 2005 | 06:09 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
i had a similar problem on my trans am. ended up being the ignition switch. I hope these starters are as good as the 3rd gen VE those things were bulletproof
Old Dec 19, 2005 | 07:11 PM
i will take it to my mechanic tomorrow and have them take a look at it cause this is giving me a really hard time when i can't get the car started in the morning for work
Old Dec 20, 2005 | 09:59 PM
i replaced one of the relay today and the car starting fine now cranks when i turn the key let's hope it keeps it that way i also notice the cars runs alittle smoother after i replaced the relay before it didn't wanted to move
shilov
Feb 19, 2024 09:40 PM
Gingerheadman
Oct 1, 2015 05:11 PM
msellas
Sep 23, 2015 09:16 PM
ajahearn
Sep 19, 2015 03:03 PM
rnb754
Sep 14, 2015 11:39 PM
