Car is lagging, please help
Old Dec 22, 2005 | 11:28 PM
radicht's Avatar
My car is lagging when I accelerate (almost leerching). It is fine once I am above 50 mph. I haven't changed my fuel filter in a while and was wondering if that is a symptoms of an old fuel filter.
Old Dec 23, 2005 | 12:16 AM
packetattack's Avatar
Get MAF checked.
Get coil packs checked.
Do you have the CEL light on?
Old Dec 23, 2005 | 01:03 AM
radicht's Avatar
It came on, but went away (I just hit 120K and thought that it was a light that would come on for 60K mile service)
Old Dec 23, 2005 | 01:21 AM
radicht's Avatar
I need to change the spark plugs as well - could this have an effect?
Old Dec 23, 2005 | 02:37 AM
Ceasars Chariot's Avatar
Old Maxima Legend
how many miles on the present plugs ? replace with ngk platinum, is the knock sensor ok ? are you using premium fuel ? check codes, fix anything that needs to be tended too, then service your engine and go from there.
Old Dec 23, 2005 | 11:43 AM
Jatan's Avatar
Do a tuneup since you need it and then come back here
Old Dec 23, 2005 | 04:41 PM
G4nismo's Avatar
get whatever codes that are stored in the ecu and then find out what they mean using the ecu fault code diagnosis. i found out i had 2 problems:
the line pressure solenoid valve due to the drop resistor mod and the knock sensor.
thought my car ran fine although it was kinda sluggish below 3000rpm but after i changed the KS, car pulled so much harder. i can peel out everytime from a stop now! WHOOO!
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
