Auto Tranny troubles
Old Dec 25, 2005 | 10:28 AM
MaXAnDy's Avatar
Hey guys. The auto tranny in the 99 max is shifting a little rough and seems to be indecisive at times. The car has 86,000 miles on it and I did a tranny tune up at about 40,000 miles. Would it be a good idea to do my next tune up now and maybe add some synthetics made to offer smoother shifting? Any input would be appreciated. Thanks.
-Andy
Old Dec 25, 2005 | 12:10 PM
UncleMax98's Avatar
What was done during the tranny tune up? It was a long time ago so maybe it is due another tune up. I think a simple ATF fluid flush may be enough. You can use Nissan ATF fluid (safe bet) or Mobil-1 ATF (my favorite).
Old Dec 25, 2005 | 05:02 PM
njmaxseltd's Avatar
Can you give us a little more detail on how it's acting?
Would it be a good idea to do my next tune up now and maybe add some synthetics.
-Andy
There is no such thing as a tranny tune up for our cars, per say. The only thing you can do is change or flush the fluid. Maybe pull the pan down and clean the magnets on the bottom and check the screen for any contamination. A flush and change over to synthetic transmission fluid does make the auto shift much better in the cold mornings and when it's really hot. I recommend Amsoil transmission fluid.
Old Dec 25, 2005 | 06:55 PM
kc10fish's Avatar
ck all ground points and make sure they are rust free........
Old Dec 25, 2005 | 09:19 PM
MaXAnDy's Avatar
Yea sorry, meant a tranny flush. In terms of how it is acting: The 1-2 shift, isn't smooth, gives a harder shift than normal. When I mean that it seems to be indecisive is that it changes between 3 and OD quite often and seems to struggle to find what gear to downshift to when giving it a little more gas. And I am assuming that the synthetic ATF will be better than the normal one from what njmaxseltd wrote, is this correct? Thanks.
-Andy
Old Dec 25, 2005 | 09:47 PM
s0ber's Avatar
-Andy
Sound's like a normal auto to me
Old Dec 25, 2005 | 09:56 PM
xlmazdawg's Avatar
At this time I can not start my own thread, so please accept my apology for this question. I own a 1996 max with a automatic, when I shift into park the car start rollin backwards and I can hear a "grinding nosie". Is my tranny going bad or what? BTW the car has a 124k.
Old Dec 25, 2005 | 09:58 PM
s0ber's Avatar
yes.
10 char.
Old Dec 25, 2005 | 11:52 PM
maximaman10's Avatar
Change the shift solonoids on the valve body. I changed mine at about 90,000 miles. The cost for them is about $ 210.00 for the parts.
Old Dec 26, 2005 | 06:02 AM
njmaxseltd's Avatar
The park pin is either broken or not seating correctly. To fix it, your tranny will have to come out and apart. Just use your ebrake and don't let it roll.
Old Dec 26, 2005 | 09:04 AM
metal_god98SE's Avatar
Well 46k miles in between auto tranny services is alot. Have the tranny fluid flushed every 25-30k to keep it fresh and you should have a longer life out of it.
Old Dec 26, 2005 | 09:07 AM
MaXAnDy's Avatar
So suggestions center around a tranny flush, and checking to see if the valve body selonoids need replacing?
Old Dec 26, 2005 | 01:44 PM
First things first, MaxAndy.......by a process of elimination.. do the easiest, most cost-effective, and obvious things first. Do the tranny flush first, if things done improve, then go to the next most probable thing that it can be. Regardless of the problem, the ATF needs to be changed anyways.
fx4five
Oct 18, 2015 06:57 PM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
zmcneely13
Sep 26, 2015 02:26 PM
