intake template
Old Dec 25, 2005 | 01:17 PM
rome06's Avatar
intake template
i kno this question has been brought up b4 numerous times, but i cant find it anywhere....does anyone know where i can get a template from so i can cut the hole for the intake to go into??? thank youuu
Old Dec 25, 2005 | 02:19 PM
Sharp's Avatar
https://maxima.org/shoptalk/sub_modi...raphics/15.jpg
i used this to help me..and just lined my center drill bit between the hump and the existing hole.
Old Dec 25, 2005 | 04:12 PM
rome06's Avatar
thanks man
Old Dec 25, 2005 | 05:19 PM
ThurzNite's Avatar
Which intake are you installing?
Jae
Old Dec 25, 2005 | 06:44 PM
rome06's Avatar
Jae
Old Dec 26, 2005 | 04:48 AM
BEJAY1's Avatar
Conecarver
Here's the Place Racing template. Once you line up your tubing you should see if it's the same or not.
http://forums.maxima.org/showpost.php?p=3638432
Old Dec 26, 2005 | 08:48 AM
rome06's Avatar
is that the actual size or do i have to enlarge it or anything?? thanks tho
Old Dec 26, 2005 | 05:15 PM
rome06's Avatar
after i installed it the CEL came on??? is this supposed to happen or what?
Old Dec 26, 2005 | 05:23 PM
Sharp's Avatar
check engine light should not come on..mine didnt...sure u didnt mess up ur MAF sensor
Old Dec 26, 2005 | 05:25 PM
rome06's Avatar
is there a way to test it....besides scanning the ecu
Old Dec 26, 2005 | 05:27 PM
NmexMAX's Avatar
dot dot dot ...
What code is it?
Old Dec 26, 2005 | 05:29 PM
rome06's Avatar
Originally Posted by NmexMAX
What code is it?
i havent tested it yet....i was seeing if there was a way to test the MAF sensor BESIDES having to scan the ECU.....
Old Dec 26, 2005 | 05:31 PM
NmexMAX's Avatar
dot dot dot ...
Why not just check the ECU?
Old Dec 26, 2005 | 05:33 PM
rome06's Avatar
alright i'll do that.....its kinda weird though, it came on right after i put the intake on....i dont think autozone is open right now so i'll do it tomorow for sure
Old Dec 26, 2005 | 05:38 PM
NmexMAX's Avatar
dot dot dot ...
Check them yourself ....
Old Dec 26, 2005 | 05:52 PM
86maxima96's Avatar
I Broke OT
autozone pwns you...
or apparently you don't own a screwdriver
Old Dec 26, 2005 | 06:14 PM
rome06's Avatar
hahaha no man its cold as ***** outside right now and im all dressed up to go out so its not really a good time to be getting on my knees and stuff and messing with it right now.....if it was the MAF wouldnt i notice a difference in the car.....because as of now i dont at all
Old Dec 26, 2005 | 06:22 PM
Sharp's Avatar
my OEM airbox (where the filter is) had a small sensor in the side of the (IIRC) lower side of the box, and it just slid into place on my CAI pipe where the hoses hook up...sure u got this in?
Old Dec 26, 2005 | 06:24 PM
NmexMAX's Avatar
dot dot dot ...
This thread is pointless at this point since we're all shooting in the dark. Whenver you get a chance to check th codes, or get to AutoZone, then you'll be ain a better position, but right now, this thread wont go anywhere because fact > speculation, and right now that's all we are able to do since you have no codes, nor a means to check them.
Old Dec 26, 2005 | 10:57 PM
rome06's Avatar
that might be it, i know i didnt hook any sensor up from the lower airbox....i dont even think i saw one
Old Dec 27, 2005 | 12:34 PM
ThurzNite's Avatar
Are you refering to the intake temp sensor? It's along the snorkel where it bends 90deg to the driver side?
Jae
Old Dec 27, 2005 | 04:18 PM
rome06's Avatar
Jae
i left that still on my car....if i took that off where would i put that sensor at
Old Dec 27, 2005 | 04:22 PM
ThurzNite's Avatar
zip-tie it to something
Jae
aw11power
Oct 10, 2021 04:57 AM
JonBlz
Oct 5, 2015 06:02 PM
maxima297
Sep 30, 2015 03:32 PM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
