weird loss of power?
Old Dec 28, 2005 | 10:49 AM
liloutlaws's Avatar
I was driving the car yesterday and randomly the engine started bogging for power (kind of like the feeling when you run out of fuel), except i had a full tank. i eased off of the gas and then re-accelerated and the problem went away. but it seems like that comes and goes.
any idea what that is? is that a known problem for 4th gen maximas?
Old Dec 28, 2005 | 05:28 PM
dko's Avatar
dko
duck and cover
bad gas, misfire, knock... there's a billion things it could have been. it's prob. not serious
Old Dec 29, 2005 | 01:38 AM
liloutlaws's Avatar
well i drove the car more today..this is definately a problem.. i feel it very often now (as if the car is being tugged on and off) when i hold the aceleration constant cruising at local speeds..the car keeps tugging on/off (feels like slight pushes from the engine) any ideas?
i'm thinking maybe the belts are worn?
Old Dec 29, 2005 | 01:53 AM
NmexMAX's Avatar
dot dot dot ...
Are there any CEL'?
Old Dec 29, 2005 | 09:38 AM
liloutlaws's Avatar
nope none that i know of. all i know is that it keeps happening more and more frequently. in neutral this does not happen. and if i accelerater hard, the feeling goes away for awhile
Old Dec 29, 2005 | 09:58 AM
speed racer's Avatar
Can you list any recent maintenance work you have done to the car. Maybe its your car telling you to change some parts.
Old Dec 29, 2005 | 10:18 AM
liloutlaws's Avatar
my mom did take good care of the car is about all i can tell you, the car died a couple of months ago. but i don't think any of the regular maintenance has been on schedule. its at 120k, and i just changed the oil. i plan on checking the pcv valve and changing the spark plugs and air filter. besides that i don't really have the tools or know how to do the rest.
Old Dec 29, 2005 | 11:07 AM
Its defenitelly a good start to do as much maintenance on the car as possible even though you say your mom kept good care of it. Look in the stickies for 60K maintenance. Just some things to do off the top of my head is changing the spark plugs, fuel filter, air filter, pcv, and clean your throttle body and IACV.
Old Dec 29, 2005 | 12:45 PM
95stillenmax's Avatar
it is probobally goost code 0304 which is your knock sensor
Old Dec 29, 2005 | 07:05 PM
liloutlaws's Avatar
you probably misread..i said didn't take good care of the car
Old Dec 29, 2005 | 07:06 PM
liloutlaws's Avatar
what does ghost code mean? and does a knock sensor actually make noise (just curious)?
and where can i find the code
Old Dec 29, 2005 | 10:02 PM
L0R1DA's Avatar
liloutlaws - from your symptoms I would venture to guess your problem is either in the departments that speed racer suggested (maintenance is the best modification for any ride) or your emissions systems. Also, read up on Auto-Rx and try cleaning your oil system with it, it helped smooth out my rough idle. Seriously invest your efforts in learning about your EGR (Exhaust Gas Recirculation) system, because it is one stupidly designed concept that will surprise you with its ability to create problems.
EGR cleaning thread- http://www.forums.maxima.org/showthread.php?t=447621
Old Dec 29, 2005 | 10:12 PM
95GLEMAXX's Avatar
yeai have the same problem and my knock sensor is bad and i have an intermittent 02 code
Old Dec 30, 2005 | 08:59 AM
Jatan's Avatar
Do a tune up and then come back here with an updated
Old Dec 30, 2005 | 09:31 AM
a ghost code just means its there but it just dosent give a check engine light, it can be found right under the intake manifold it is heald on by 1 12mm or 14mm screw I cant remember, it is kind of a pain to change but it can be done without removing the intake manifold, it dosent make any noise, its just a sensor
Old Dec 30, 2005 | 12:06 PM
liloutlaws's Avatar
ok cool..i'll give you guys an update once i change everything.
2 side notes...
where do you guys buy oem parts online? can you recommend a cheap site?
also need a place to buy NGK copper spark plugs (for some reason Kragen doesn't have it in stock)
and there is something engine oil leaking from the car...i checked all of the components and they're either torqued correctly (filter is on tight). the gauge still has shows the right level. does the oil filter requre any type of additional cross screw (i know they recommend that for some hondas)?
thanks!
Old Dec 30, 2005 | 12:17 PM
MorpheusZero's Avatar
I've noticed that whenever I shift from 3rd-4th, land at about 2k and give it 30-40% throttle, the engine will bog momentarily. This is basically the definition of being in closed-loop, right? Is this a problem or is it rather normal?
Old Dec 30, 2005 | 12:34 PM
the_3d_man's Avatar
check the oil pressure sender. It's on the side of the oil pan. It costs like 5 bucks at autozone and it is a frequent culprit for leaking.
Old Dec 30, 2005 | 01:28 PM
liloutlaws's Avatar
any picture of what you're talking about? i checked teh stickes..and the how-to's don't ever mention it.
Old Dec 30, 2005 | 03:58 PM
liloutlaws: For OEM parts try Pinnacle Nissan. Make sure you get NGK sparkplugs, if your NA its best to get the Platinum Spark plugs. You can go to Autozone or Napa and get your Pure One Fuel Filter, K&N air Filter or Fram, any name brand PCV, and Throttle Body Cleaner. That should get you started. Ooo go to Sears and buy one of those tool sets with 60 or 90 something pieces. That should get you started with all the simple maintenance repairs.
The OIL filter is simple screwed on with your hands. I use a Oil filter wrench and do a 1/4 turn just to make sure its tight. But most of the time I have oil there b/c the filter is put on horizontal and I'm lazy to keep cleaning it.
Old Dec 30, 2005 | 10:01 PM
95GLEMAXX's Avatar
my car does the same thing sometimes and my cel light goes on and off and i know its one of the 02 sensors slowly dying
would a bad 02 sensor have anything to do with this?
Old Jan 4, 2006 | 12:24 AM
sam_918's Avatar
Regarding Ghost Codes
If the cel is on for a few days and then turns off, did the problem go away, still there without a code or still there with a code? I didn't self check when it was on or since its been off.
Old Jan 4, 2006 | 04:28 AM
A Ghost Code means that the CEL, or engine light, will not turn on. I suggest you start looking in the FAQ section and get familiar with the site b/c your looking to get flamed by the old heads.
Old Jan 9, 2006 | 04:22 AM
jeffsrjr's Avatar
could be your mass air flow sensor.
Old Jan 9, 2006 | 11:16 AM
liloutlaws's Avatar
how do you clean or check that?
Old Jan 9, 2006 | 12:52 PM
NmexMAX's Avatar
dot dot dot ...
Spray K & N filter oil on it and wipe down with cheesecloth.
Old Jan 24, 2006 | 11:19 PM
sam_918's Avatar
Flame all you want, I'm just a kid trying to learn about my car and if that's funny or annoying or whatever to you I really don't care. I remember the rules said no flaming but I didn't see anything about asking questions no matter how stupid they are to you.
Old Jan 25, 2006 | 11:56 AM
Garrick's Avatar
liloutlaws: . Make sure you get NGK sparkplugs, if your NA its best to get the Platinum Spark plugs.
Or the NGK Iridium IX's like I got.
Old Jan 25, 2006 | 01:58 PM
99I30lmtd's Avatar
amen brotha
the only stupid question is the one u dont ask
ignorance is not stupid we are all ignorant, even if some of us pretend to know it all
Old Jan 25, 2006 | 02:09 PM
NmexMAX's Avatar
dot dot dot ...
Flame all you want.......
No need to tell me, I already do.
This isn't even your thread though .
Old Jan 25, 2006 | 02:54 PM
Garrick's Avatar
TallTom
57
Oct 14, 2025 05:16 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
