larger oil filter for the 3.0??
Old 12-31-2005 | 08:40 AM
atomztwins's Avatar
In my Jeep and my Caravan I run an oil filter from a 5.0 Mustang. They have the same threads and the 'stang filter is a lot larger which equals more oil capacity and filter surface area. I only run Wix filters and mobil 1 full synthetic and change the oil every 10k. Is there a larger filter for the Max 3.0? Maybe from a Murano or newer Max or Z car or something? Any help would be appreciated.
Old 12-31-2005 | 09:32 AM
kcryan's Avatar
yea you can use a mobil1-105 filter, but for it to fit you need to grind part of the block, not worth it if you ask me.just use a good oil and filter and this engine will last forever with out much work.
Old 12-31-2005 | 09:43 AM
nismology's Avatar
What does a larger oil filter have to do with the engine block?
Old 12-31-2005 | 09:45 AM
kcryan's Avatar
if you try to screw it on it will not fit, if you get a dremel or somthing and grind down some piece of metal (i think its on the block i could be wrong) it will. its in the stickies somewhere on this site.
Old 12-31-2005 | 11:36 AM
Bobo's Avatar
If you're extending your OCIs to 10K, I hope you are doing a lot of highway miles and replacing the oil filter after 5K.
Old 12-31-2005 | 05:07 PM
atomztwins's Avatar
I run good air filters to keep the dirt out and drive both city and highway. Dirt is the bastard when it comes to oil in a car that does no towing. An, like I said, I run full synthetic and a WIX filter. Thanks fokes....
Old 12-31-2005 | 05:15 PM
pocketrocket's Avatar
Use an STP S6941.
I use it on my 95 ever since I started doing 6k oil changes.
Old 12-31-2005 | 05:48 PM
nitromax's Avatar
what car & engine is the S6941 stp filter supposed to fit? it may be available in different brand near me. thanks for the info.
Old 12-31-2005 | 06:04 PM
njmaxseltd's Avatar
Physical size doesn't correspond to a better filter.
I worked for a company that made hydraulic filters. The filter media and it's construction was the key to filtration efficiency, flow rate and dirt holding capacity.
Old 12-31-2005 | 06:52 PM
i30krab's Avatar
If you want a larger filter, get an oil relocation kit from permacool and then you can go as big as the old ford or chevy truck filters that hold a quart of oil!! I don't think we are worried about the quality of the filters since most are good enough if changed regularly. The important thing is adding volume to your oil capacity. A larger filter plus lines and a big oil cooler can add 1 1/2
quarts to your engine. Think about the guys who buy larger aftermarket oil pans!
Old 01-01-2006 | 04:00 PM
blkmaxx97's Avatar
Amsoil SDF-36 on mine & oversized.
Old 01-02-2006 | 12:45 PM
SMX95's Avatar
Use OEM filter not a bigger filter you are doing nothing by doing that. Change your oil every 2800 miles and you are set.
mclasser
22
11-12-2020 02:58 PM
06-06-2017 03:01 PM
05RLS2
04-14-2016 12:49 PM
Justin Kroll
10-01-2015 08:03 PM
wiseguy6199
09-29-2015 06:00 AM
