300z BBK installed....can't move....
Old 01-03-2006, 11:48 AM
  #41
I never narc'd on nobody.
Akumachan's Avatar
Originally Posted by MaximaSE96
http://www.tirerack.com/wheels/tech/...jsp?techid=101
center of wheel to where the plate meets the face of the rotor hat
Next time I'm bored I'll find out what offset mine are, thanks for the info.
Akumachan is offline
Old 01-03-2006, 11:56 AM
  #42
Maxima Owner
MaximaSE96's Avatar
no problem.....
MaximaSE96 is offline
Old 01-03-2006, 11:59 AM
  #43
matty's Avatar
How much did that Rim/Tire combo run you ?? Im thinking of doing the BBK up front and getting rims and tires I can use for the winter, and ditching my Saw-blades for good.
-matt
matty is offline
Old 01-03-2006, 12:03 PM
  #44
STFU n00b!
Matt93SE's Avatar
My rotors look exactly like the original posters, and we are both riding on 17x8 Fn01r-c's, so unless they made them in multiple offsets, which I'm not saying they didn't, then they should be the same.
FN01R-C come in at least 4 offsets in 17x8 to fit our lug pattern.
the 35mm fit just fine over my brake kits, but with the cobra rotors, they will need spacers.
Matt93SE is offline
Old 01-03-2006, 12:07 PM
  #45
Maxima Owner
MaximaSE96's Avatar
my spoke design is different i might need them for yours...either way i will need them for aut0-x..PS Email replied to you
Old 01-03-2006, 12:17 PM
  #46
Akumachan's Avatar
Yeah, they were so close to clearing, I was really hoping they would, but after one rotation they had scraped a bit of paint off my calipers, so I just went and bought the thinnest spacers I could find.
The wheels I bought off an old .org member that wrecked his car for $800, and then I paid another $320 for all 4 tires and had a friend mount and ballance them for free. Getting 2 new tires today because my front are completely smooth, not even 1mm of tread left, so thats another $300 (friend cant do it for free anymore )
Old 01-03-2006, 03:26 PM
  #47
iansw's Avatar
15mm spacers (front) and 5mm spacers (rear) are on the way!
iansw is offline
Old 01-03-2006, 03:31 PM
  #48
Maxima Owner
MaximaSE96's Avatar
i am gonna get ones for the rear too...just to try and even it out a little bit
Old 01-03-2006, 03:33 PM
  #49
iansw's Avatar
Yeah - that's the idea.
I'm going to replace all the rear lug bolts with longer ones as well, even though some say you don't have to with 5mm spacers - just to be safe.
iansw is offline
Old 01-03-2006, 05:20 PM
  #50
vsamoylov
that is the one thing i dont like about this kit and the person that made it. i never read anywhere that spacers are needed or that the pad doesnt rub all the way on the rotor.
Old 01-03-2006, 06:20 PM
  #51
iansw's Avatar
Ummm.....
Spacers are only needed if you don't have the right offset and spoke design on your rims.
I was well aware of the possibility before I started my project.
And who cares if the pad doesn't rub to the center of the rotor. The pad itself makes full contact and stops like mad.
Look at a Wilwood BBK - same thing.
iansw is offline
Old 01-03-2006, 06:24 PM
  #52
Maxima Owner
MaximaSE96's Avatar
ill prolly do that too......H&R spacers for the front....NISMO 50mm Studs for the rear with 5mm spacers...
thats what i like about Matts Kit...from pictures it looks like pads make it to center of rotor....and its only .4" diamter smaller
Old 01-03-2006, 06:25 PM
  #53
iansw's Avatar
I think the H&R 5mm spacers come with new studs.
I'll find out for sure on Friday when they get here.
iansw is offline
Old 01-03-2006, 06:28 PM
  #54
Maxima Owner
MaximaSE96's Avatar
http://optionsauto.com/prodinfo.asp?number=HR1065662
no u have to order sepately
Old 01-03-2006, 06:48 PM
  #55
vsamoylov
pad doesnt make full contact with the rotor either
Old 01-03-2006, 06:54 PM
  #56
Kevlo for President
Kevlo911's Avatar
vsam, How much were the 2piece rotors?
Kevlo911 is offline
Old 01-05-2006, 06:14 PM
  #57
iansw's Avatar
Nope.
I just got 2 boxes - 1 for the 15mm spacers and one for the 5mm spacers.
Both sets came with new studs. (20 total studs)
I can take pics if you need proof.
iansw is offline
Old 01-05-2006, 06:25 PM
  #58
Maxima Owner
MaximaSE96's Avatar
i beleive u ....it just says in the edescription u have to ordewr separately......are htey already in the spacer or do u have to put them in....or do they go in the hub itself...but i would like to see pics anyway just to see what i will be expecting
Old 01-05-2006, 06:38 PM
  #59
MAXRB8's Avatar
Welcome to the 300ZX BBK club! I have a bit if a write up on my domain page 3 if anyones interested. I'm waiting for my second set of 15mm H&R spacers for the rear. BTW G35 18" coupe wheels don't require any spacers I tried one on at the dealer.
MAXRB8 is offline
Old 01-05-2006, 07:37 PM
  #60
iansw's Avatar
Just discs and seperate lug bolts.
I see now - there's several models sold.
http://www.optionimports.com/h-r-spacer.html
The DR Series does not come with bolts, the DRS (what my receipt says I bought) do.
Although that says 10-40mm, and these are 5mm....hmmmm.
iansw is offline
Old 01-05-2006, 08:11 PM
  #61
Maxima Owner
MaximaSE96's Avatar
yea iwas going for teh DRS with the 15mm....but i didnt see the 5mm in DRS...
PS my BBK cam from matt today i cant wait to put it on
Old 01-05-2006, 08:13 PM
  #62
vsamoylov
2 piece cobra rotors were about $500 shipped.
Old 01-27-2006, 02:33 AM
  #63
Langley AFB Sux
Aaron's Avatar
Guess I need to get the Cobra rotors...........
Back when I did my 300ZX TT brakes i got my aluminum calipers for 70 shipped........
Aaron is offline
Old 01-27-2006, 06:06 AM
  #64
iansw's Avatar
Update:
Got them installed and WOW my braking power is so much better.
I expected it to lock up too easily and be hard to drive - but really it's not a problem once you get used to it....just brakes WAY more effectively in general....especially coming down from high speed.
One of the best mods I've done yet....
iansw is offline
Old 01-27-2006, 07:31 AM
  #65
Kevlo for President
Kevlo911's Avatar
How much slower does the car feel?
Kevlo911 is offline
Old 01-27-2006, 07:59 AM
  #66
vsamoylov
slower? you should ask that question to people that have huge rims on their max that weight a ton. but on the brakes i actually saved 8 pounds total.
04-16-2020 05:15 AM
Quickgtp
04-13-2017 03:30 PM
maxfever1987
11-19-2016 08:01 PM
BkGreen97
04-02-2016 05:47 AM
CHAZMAX
01-29-2003 07:14 AM
Quick Reply: 300z BBK installed....can't move....
