Chattering from Timing Chain
#41
Originally Posted by max88q
Thanks, Im just going to do the timing chain tensioner.
When you are ordering the timing chain tensioner, they may assume the cam chain tensioner because the ID on the illustration is the same. Make sure you are ordering the "main timing chain tensioner". Those are often mixed up with the camshaft timing chain tensioners. You'll have to be specific with them.
Also, a quick thing to note here. The part number for the timing chain tensioner for a 4th gen main tensioner has superceded to the 5th gen tensioners part numbers. There's a FSB thing about the 4th gen tensioner defects. In addition, this superceding affects the chain guide that goes with it. So you'll end up needing both the new main timing chain tensioner and a new chain guide. On post #37's illustration, you will need both #20 and #21 on there. I just want to clear this up so you'll know what to tell those guys.
#43
Originally Posted by JClaw
Take 20 minutes to replace it yourself using a ratchet with a 10 mm socket and a rag to stuff in there.
If he's buying the superceded chain tensioner, he'd have to replace the new chain guide. Then, it won't be a 20 minute job anymore.
#44
Thats the timing chain tensioner right?.........I'm currently doing my water pump and I had to remove this.........not too hard to remove and replace.........just get a set of magnetic inserts for ur sockets so you dont lose the bolt inside.
#45
#46
#50
that's right, if you are doing the guide too, you can't do it thru the hole. you'd have to pull the whole cover off. It's a job, but it's recommended with the newer tensioner design. The new tensioner has an angled hammer that sit flush to the hammer face on the new chain guide. If you use the new tensioner without changing the guide, it won't sit flush and I dont' personally know the outcome, I changed the whole set.
sctludwig
09-01-2022 01:32 PM
kjlouis
10-03-2015 05:29 AM
trungg86
09-04-2015 04:58 AM
