Heat fixed!
Heat fixed!
Well as some of you know I have had a long standing NO HEAT problem. I had the heater core changed because it leaked, radiator changed because of a broken neck thermostat changed and temp sensor changed and still no heat. Finally brought it to a mechanic and he says "It's either a problem with you auto climate control or heater core valves not opening properly. $200 to diagnose + whatever work I have to do"
I said no way, I'll deal with no heat before i shell over $200+. Well I'm drivin to work the other day and notice steam comin out the front of the hood. The radiator was leaking. 1 year and 5 days after install. Warranty was 1 yr. So I go to Autozone and get the lifetime warranty radiator put it in [easiest job I have ever done on my max, took about 1 hour]. So I get done and the heat was a little better but not HOT....I was not to surprised because of all the problems with the lack of heat problems I have had. So I decide to flush out the heater core. I connect a hose to the inlet and spray. A very small amount of water comes out. I repeat the process over and over again and then BAMN a loud gush of water comes out and flows pretty hard, something was in there and not allowing the water to flow through the heater core. I re-assemble everything and now heat blazes out. I actually have had to turn the heat off a couple times
Sorry for the long story just very excited to have heat for the 1st time in 1 1/2 years...
![lolrun](https://maxima.org/forums/images/smilies/lolrun.gif)
Originally Posted by njmodi
I remember reading your earlier threads about this problem and trying to help you out. Glad you got the problem fixed.
![ThumbsUp](https://maxima.org/forums/images/smilies/thumbsup.gif)
Yup. When you say you ran water through the heater core, did you go right into the inlet at the firewall? Is it easier to get to from above or below the vehicle? This might be something more of us should do (even as a maintenance item)...
From the top, not to difficult to get to. I dis-connected the hose by the valve not at the firewall so i could use the inlet hose to spray into. Without the hose there isn't enough room to get the nozzle in there and spray, so i just stuck the hose nozzle to the end of the hose,took off the bottom hose and spray away.
Hi,
Was wondering if someone has some time could they write a quick write up to this? Also was wondering if this is normal.............my car has to FULLY warm up to blow any heat at all? I was thinking its normal but when I drove my dads camry the other day......the heats works like literally 5 seconds after tunring the car and heat on...Thanks for any help
tarun900
19
12-20-2021 06:57 PM
