97 Stock Wing removal
there are 4 bolts on the bottom closest to the 3rd brake light (inside the trunk) then the 4 clips on the outside edges. dont worry about breaking the clips they will most likly break anyway. when you put it back on make sure you use 3m double sided tape, bolts, and all new clips. it should help with the rattles
i have been previously trying to use the 3m molding they call it tape but its more like a clay and that doesnt hold anything down at all. Are the clips expensive and do u think putting a rubber washer on the bolts will help with vibrations?
mine had a rubber piece under the wing from the factory(between the wing and the trunk lid). Use the 3m molding tape (the black stuff with red backing) make sure you clean both surfaces very good and don't touch the tape. Those clips are about $20 a set I think but they are the right way to do it.
http://forums.maxima.org/showpost.ph...4&postcount=19
there is a harness in the trunk with a plug.
Originally Posted by Royceeee
So do in order to get the old clips off on the trunk do you also use that pry tool? and how hard is it to put the new clips on?
www.nissanpartscheap.com sells them pretty cheap (duh), that's where I got mine
James92SE
142
Jan 2, 2024 09:23 AM
The Frye
Sep 2, 2021 11:03 AM
