Got an alignment but rear wheels tilt inward
Ok guys I went and got an alignment this afternoon. Everything in spec now except maybe off by a few hundredths of a degree nothing youd ever notice.
Guy looks at the rears and notice they arent adjustable but my rear wheels are tilted inward. Left at -1.47 and right -1.07 and in 04 there was an alignment performed and the rear was -1.2 and -1.0.
What my problem here guys? Would a camber bolt kit help? Is it my rear sway bar?
the rear is setup with toe in to promote understeer. your measurements didnt change very much, so i wouldnt worry.
you cant adjust camber or caster on the rear. unless you have the beam bent to change toe, which only a few select people know how to, your stuck with it.
Yeah, there is rear toe-in from the factory. There was some talk last year about people bending the rear beam to correct this and greatly reduce understeer of the car. I believe our Sentra SE-R bethren started this, if you are interested in looking into that.
Huttig2009
Sep 25, 2015 03:31 PM
BobMax
Aug 15, 2015 12:35 PM
