Home Made Rear Sway Bar Project - Need Ideas
Old Jan 16, 2006 | 03:18 PM
Wheelie King's Avatar
My cousin and I are trying to fit a 3rd Gen RSB on a 4th Gen and 5th Gen. I pulled the RSb from a 93 Maxima today and cut off the end links. It is very close to fitting but its a couple inches too long. In order to fit on the inside of the rear axle trailing links the way the aftermarket RSB seem to mount, it will need to be about 2.5 inches shorter.
I'm considering a couple options: 1) mount it underneath the RATLs so that the ends can extend beyond the RATLS; or 2) have 2.5 inches cut out of the center of the RSB and welded back together. If it is cut then we may cut it to the right length to fit snugly on the inside of the RATL and just have it welded in.
Anybody have any helpful thoughts?
Old Jan 16, 2006 | 03:41 PM
Mr. Blue Sky's Avatar
DON'T CUT IT. Once you do, you have compromised the structural integrity of the RSB. It will either break or not do you any good performance wise. why go through all that trouble?
Old Jan 16, 2006 | 03:43 PM
Dubbya's Avatar
VK56 Inside
I wouldnt cut it either. Maybe bend it?
Old Jan 16, 2006 | 04:46 PM
darklegend06's Avatar
bending it would be a great idea. Also bend it at the corner for more strength at those location. Just an idea.
Old Jan 16, 2006 | 05:04 PM
nismos14's Avatar
§è~® f®ÈÄk
You could weld extensions on the arms that angle in
Old Jan 16, 2006 | 05:36 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
heres a great thought....buy a 4th gen RSB
Old Jan 16, 2006 | 05:49 PM
Matt93SE's Avatar
STFU n00b!
throw that tiny pencil d!ck sway bar in the trash and buy one that's made for the car.
assuming you work for minimum wage, you could work the hours to pay for a Progress RSB in less time and money than it would take you to make the 3 gen RSB work on your car.
Old Jan 16, 2006 | 05:54 PM
amimaxima
dont be a red neck pecker wood, you can buy a new one for 150 shipped off ebay
Old Jan 16, 2006 | 06:22 PM
El_Presidente
Don't be a cheap azz, and go buy a sway bar that is made for the 4th gen. That 3rd gen bar is not the right stiffnes, because they have IRS, instead of the new and improved beam axle.
Old Jan 16, 2006 | 06:50 PM
OK, thanks. I won't cut it. I will try bending it. It shouldn't take much bending to get it to fit.
Old Jan 16, 2006 | 07:59 PM
ImmaSquashYou's Avatar
i think i sold my used progress bar for like $80.....soooo........i mean.....thats like 12 times to mcdonalds, 5 decent dinners, or just one VERY good meal...
Old Jan 16, 2006 | 09:40 PM
maximaman10's Avatar
You can get 1 at http://www.customenterprise.com for about $ 55. shipped to your door.
Old Jan 16, 2006 | 09:55 PM
Nissan 6's Avatar
no....his is talking about a rear sway bar not a rear strut bar. The rear sway bar on CE is far more expensive like 140.
Old Jan 17, 2006 | 04:17 AM
1996blackmax's Avatar
Get the aftemarket RSB and save your self the hassle and time.
Old Jan 17, 2006 | 07:38 AM
Dubbya's Avatar
VK56 Inside
I hope you got a good way to bend it. Remember these are ment to stop the weight of the car from swaying.
Old Jan 17, 2006 | 08:46 AM
MaximaSE96's Avatar
Maxima Owner
ok so 3rd gen RSB like 14mm+/-
Progress 4th Gen Sway Bar 22mm
Old Jan 17, 2006 | 04:13 PM
True - The 3rd Gen RSB is smaller. I don't know how thick it needs to be in order to be effective.
If it doesn't work then there is no real loss, except for a little time and a little trouble. If I really wanted to save trouble then I'd just buy an aftermarket bar online, take it to the local garage and pay someone to put it on for me. I don't want to rely on off the shelf parts too much without using some imagination. and at least trying something different.
Anybody have a good picture of their aftermarket bar attached to their 4th or 5th Gen? If so then please post it.
Old Jan 17, 2006 | 05:34 PM
MaximaSE96's Avatar
Maxima Owner
it takes like 15 min to install a 4th gen sway bar it 8 bolts
ef9
Aug 27, 2015 07:21 AM
seesole
Aug 26, 2015 11:22 AM
Dasmith
Aug 25, 2015 10:15 PM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
