Testing Crank POS sensor!!!!
Old Jan 19, 2006 | 07:51 PM
f550maranello2's Avatar
Well im having timing issues in my car... im blaming this sensor....
The procedure in the FSM is to remove the sensor... turn the ignition to "ON"
and use a volt meter to measure the sensor from the harness plug... then touch the sensor tip with a screw driver and you should get 5 volts... when you pull it away it should go to 0.....
i get 145 millivots until i touch the sensor with the screwdriver it jumps to 220 milivolts for just a second and then remains at 145 millivolts....
If someone has tested this sensor this way please tell me what you got...
Old Jan 20, 2006 | 08:46 AM
Tim96I30t's Avatar
Are you using dc voltage on your meter?
Old Jan 20, 2006 | 09:26 PM
yea... i am... but i tried both just to be sure... still no luck...
mvm062
Nov 30, 2020 09:00 AM
02PearlSE
Feb 1, 2016 12:37 AM
gustavison
Oct 4, 2015 06:50 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
conansriver
Sep 11, 2015 10:26 AM
