how to remove torque converter?
Old Jan 23, 2006 | 01:03 PM
ktranne's Avatar
NOOB
I have a 96 maxima, I would like to know how to get torque converter out? I got the transmission out.
Really thanks for any answers guys.
Kelvin.
Old Jan 23, 2006 | 01:29 PM
s0ber's Avatar
I think theres 4 bolts holding it down to the flexplate on the engine...
Theres a small plate or something like that somewhere that you have to remove, it will allow you to remove those 4 bolts, you have to turn the crank to get access to them...
Im sure someone will shine on on this..
Its in teh FSM if you have it.. in AT removal.
Old Jan 23, 2006 | 03:41 PM
Jime's Avatar
Is the converter still on the engine or in the trans?
If its on the engine then like sOber says you have to remove the 4 bolts holding it to the flexplate one at a time by turning the crank. The best way to remove the trans is with the converter still attached so you don't lose all the fluid. You do that by removing those bolts before separating the engine and trans.
Old Jan 23, 2006 | 03:43 PM
f550maranello2's Avatar
all you need to do is turn it clockwise and GENTLY pull it out with TWO hands.... when you put it back in.. same deal put in and rotate it clockwise untill you hear it click 3 or 4 times...
Old Jan 23, 2006 | 03:50 PM
Jime's Avatar
That depends on whether its still on the engine or trans. He hasn't said yet. If its on the trans, yes it just pulls right off.
Old Jan 23, 2006 | 03:59 PM
Uhhh... he said the trans is out... in the first post
Old Jan 23, 2006 | 04:29 PM
Jime's Avatar
But he didn't say where the converter was. It could easily be on the engine or the trans.
Old Jan 23, 2006 | 04:46 PM
s0ber's Avatar
Chances are its on the engine because he said the tranny was removed... If it was as easy as pull off the transmission im sure he woulda figured it out.. The remove plate and remove 4 bolts off flexplate is the tricky part, so makes sense for it to be still mounted onto the engine...
/thread!
Old Mar 12, 2012 | 03:29 PM
xPROJECTMAXIMAx's Avatar
hey guys i have a 1999 maxima trying to remove the torque converter and unfortunatly converter is still hooked to the motor, whats the best way to remova the converter?
i pulled starter but no room with socket and rachet.
i keep hearing that there is an access panel that i will have to remove to get gd access to the converter bolts...
any ideas?
Old Mar 12, 2012 | 04:29 PM
BenL's Avatar
any ideas?
You have to be under the car to get to the access panel. The access panel is secured by 2 bolts (according to the FSM on AT-191 -- I haven't had to do the job on a Maxima yet, but I've done automatic transmissions on other cars).
Once the access panel is off you spin the crankshaft manually with a breaker bar and remove the bolts one by one until all of them are removed, at that point you unbolt from the engine and remove the transmission from the car -- assuming you have all of the electronics disconnected and the axles removed obviously, you don't want to get hung up or break anything.
Old Mar 12, 2012 | 10:35 PM
maxed_out_99's Avatar
2 10 mm bolts hold a little black plate on the engine this is the access plate everyone is telling you about pull that off turn the crank until you see 12 mm bolt number one repeat this three more times keep your hand on the TC or it will hit the floor and possible damage it and definetly make a huge mess
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
jaydot901
Sep 29, 2015 01:18 PM
