ECU blinks on and off
Old Jan 23, 2006 | 05:19 PM
vincetti26's Avatar
I had just put in my new system in and i disconnected the battery terminal to put the power cord for the AMP. Then when i screwed everything back on thats when the ecu light on my dash blinks on and off constantly. I tried resetting the ECU but it did'nt work? What can be the problem....Thanks
Old Jan 23, 2006 | 05:21 PM
s0ber's Avatar
You mean the CEL light?
Old Jan 23, 2006 | 05:28 PM
vincetti26's Avatar
What i meant is the check engine light on my cluster blinks on and off.
Old Jan 23, 2006 | 05:33 PM
s0ber's Avatar
Yes, the CEL.... Did you mess with the screw on the ECU?? Is it blinking a code or just blinking on/off
Old Jan 23, 2006 | 05:44 PM
vincetti26's Avatar
Yes i did because i thought by resetting it the blinking would go away. Well it looks like a pattern when it blinks.
Old Jan 23, 2006 | 05:45 PM
njmodi's Avatar
Do I get a tax break?
Read the ECU sticky and figure out what code is being flashed and then report back.
Old Jan 23, 2006 | 06:24 PM
vincetti26's Avatar
alright its 0804. It went 4 long pulses, 1 long pulse, 3 long pulses then 4 fast ones. The code definer said; Automatic Transmission Control Unit signal to ECU but mine is a 5 speed.
Old Jan 23, 2006 | 06:28 PM
njmodi's Avatar
Reset the ECU (then the screw all the way CW, pause for 2 seconds and then back all the way CCW, then turn off the car. See if the code reappears.
Old Jan 23, 2006 | 06:31 PM
NmexMAX's Avatar
dot dot dot ...
Then you have an ECU which came from an automatic.
Old Jan 23, 2006 | 06:51 PM
Supermax95's Avatar
+1
I have heard that you can put an automatic ecu in a 5 speed but it will give you codes...HOLY **** I HAVE 900 posts
Old Jan 23, 2006 | 06:55 PM
s0ber's Avatar
Old Jan 23, 2006 | 06:58 PM
NmexMAX's Avatar
dot dot dot ...
I have 1.1128 x 10^4
Old Jan 23, 2006 | 07:00 PM
njmodi's Avatar
I have 1.1129 x 10^4
Fixed... Now stop posting, or I'll have to keep editing this post
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
BrandonCause
Sep 14, 2015 10:41 PM
