Front Pipe replacement $$ any other solutions?
Old Jan 24, 2006 | 12:57 PM
jacklefataliste's Avatar
Went to a dealer to check the noise in my exhaust, they checked it for free since I was doing an oil change (I checked the exhaust in the morning -20C and there was smoke coming from a gasket before the catalyst) so I thought that was it. The mechanic checks it and tells me the front exhaust tube is broken and that I would need a new front pipe (1000$CDN = 870US). Now I'm going to check other shops for a third opinion, but if that's it, what else can I do instead of paying that much? The noise isn't too bad but I like my ride quiet.
Old Jan 24, 2006 | 01:08 PM
Entropy's Avatar
Aftermarket Y-Pipe = 200 bucks, give or take...
Old Jan 24, 2006 | 01:21 PM
speedymax99's Avatar
go with a y pipe that a lot cheaper
Old Jan 24, 2006 | 01:32 PM
86maxima96's Avatar
I Broke OT
plus the wonderful performance gains! yea, sounds like your y-pipe must have a leak or something. is it rusted out bad? this is a part that is commonly replaced by almost all max owners even if their pipe isn't busted. by getting an aftermarket y-pipe, you will be putting larger, free-flowing pipe in place of the stock restrictive and 'cat-ed' piping. that would probably be your best option as you can get a stainless steel aftermarket pipe for right around $200 dollars. It bolts right in; something you can do yourself in your garage. if not that, you could also check the classifieds and pick up someone's stock y-pipe if you don't want an aftermarket one, but you might as well go with the aftermarket one.
check out www.lssexhaust.com or www.warpspeed.com for their pipes. There are others, so just search around a bit. also, check the stickies and http://maxmods.dyndns.org/ for everything else.
(wow, i felt generous today, lol!!)
Old Jan 24, 2006 | 01:43 PM
njmodi's Avatar
Do I get a tax break?
OR you can buy a stock replacement y-pipe for 50 bucks from the 4th Gen classifieds section... lots of alternatives to the dealer
Old Jan 24, 2006 | 01:47 PM
86maxima96's Avatar
I Broke OT
or less! people will practically give them away just to make room in their garage!
Old Jan 24, 2006 | 02:18 PM
MaximaSE96's Avatar
Maxima Owner
budget to the rescue lssexhaust.com is your friend
Old Jan 24, 2006 | 04:52 PM
99grnmaxgxe's Avatar
$870 is way too much, go A/F and tell the deal to f**k off.
Old Jan 24, 2006 | 04:54 PM
Okay, here's my nice side: http://forums.maxima.org/showthread.php?t=448036
and
http://forums.maxima.org/showthread.php?t=452505
Old Jan 24, 2006 | 08:59 PM
What model should I look into if I don't care about performance and I want minimal noise, at least close to the stock pipe? I appreciate all the help.
Old Jan 24, 2006 | 09:26 PM
RA030726's Avatar
I'm nutty for Nissans
ebay has some cheap stock style y pipes, with cats in them.
stromm
Aug 27, 2015 04:13 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Balkins
Aug 12, 2015 06:39 AM
Samedi
Aug 12, 2015 01:54 AM
kirkhilles
Aug 8, 2015 10:53 AM
