loud belt need help
Old Jan 24, 2006 | 04:38 PM
achebee4you's Avatar
loud belt need help
does anyone else have this problem when they start their car in the morning, well im in fl and it always kind of humid in the morning or at least a lot of moisture in the air and dew on the cars, and damn ever since i've gotten down here my damn belt is squeaxky as hell i think its the serphantine belt, its on rght side it really light annoing high pitch squeal but it disspears after highways driving for about 25 mins but damn its annoying it sound like a dirve a POS, but the car runs fine, and i did try belt dressing and the noise just gets louder so that didn't help, it actually after using belt dressing one time the noise persisted for a whole week even after the car was warmed up, any help would be much appreciated
i really don't want to replace it, i woner what a shop would charge??
Old Jan 24, 2006 | 04:48 PM
99grnmaxgxe's Avatar
A shop will probably charge about $50 for labor and parts, try to tighten it.
Old Jan 24, 2006 | 05:02 PM
ooh tightening it, i may try it, i ckeck out the hayes to see if it has dyi instructions for it, if not i may ask u how later
Old Jan 24, 2006 | 05:08 PM
njmodi's Avatar
Do I get a tax break?
If you can tighten it, you can replace it - the process is exactly the same. The Haynes manual covers the tighetening/replacement.
Old Jan 24, 2006 | 05:12 PM
NmexMAX's Avatar
dot dot dot ...
Take it to a shop because it's never been done nor posted on maxima.org, so we have no experience with it.
Old Jan 24, 2006 | 05:29 PM
MaximaSE96's Avatar
Maxima Owner
whats a belt.....TURN THE TENSIONER A FEW TIMES
Old Jan 24, 2006 | 06:09 PM
NmexMAX's Avatar
dot dot dot ...
Make sure the pulley bolt is loose as well ...
Old Jan 24, 2006 | 06:20 PM
njmodi's Avatar
And while you're at it, just swap the belts out...
Old Jan 24, 2006 | 06:23 PM
NmexMAX's Avatar
dot dot dot ...
Inspect, adjust or replace.
Or get reamed by a shop
Old Jan 24, 2006 | 08:01 PM
poorbrokekid's Avatar
my max does the same thing, even though i had a new belt put in and it didnt go away, now it makes this weird noise in the morning like a squeal and then it sounds like a bird real fast haha. but after the initial noise (about a second) it goes back to normal
Old Jan 25, 2006 | 06:07 AM
agent86's Avatar
noise when idling
my maxima has a high pitched noise when idling.
i'm still trying to figure out if it's a belt. it sounds more metallic to me and only happens AFTER the car warms up.
Old Jan 25, 2006 | 07:03 AM
NaloGrove's Avatar
If you already had it replaced and it continues to make the same noise, they probably didn't tighten it down enough. A new belt should know squeek or sound like a real fast bird chirping.
Old Jan 25, 2006 | 04:31 PM
konak85's Avatar
Its probably the idler pulley or belt tensioner pulley like me. The bearings are shot.
markevans999
Oct 25, 2015 08:27 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
