HELP!! did an install and now have problems
Old Jan 25, 2006 | 04:31 PM
massfastmax's Avatar
OK, so i bought an I 30 auto dimming mirror off Jepht20 the other day and decided to install that and my led dome light that i bought off Metal Maxima yesterday. Everything went fine until it got to dark so i called it quits and left my car all in peices last night. Today i finished off the install and the led dome light is working wonderfully, and the I 30 auto dimming mirror seems to be working fine also, but upon further inspection of my car i realized that my switches on the drivers side door no longer controlled the other windows, and then tried the other window switches and they didn't do anything either. I then checked all the fuses that it could have been, although i didn't really think it was a fuse problem, and they were all fine. Now that i have searched window problems and tried to find my chiltons book and couldn't find it I am hoping that some one on the .Org may have had a problem like this and can help me out.
BK
Old Jan 25, 2006 | 04:34 PM
Jepht20's Avatar
Custom User Title...
did you recently do door switch leds too?? where did you get your power from?
just got your pm now, that's why i haven't responded. i never actually installed it in my car because i bought a broadway mirror instead.
Old Jan 25, 2006 | 05:08 PM
No i haven't done led's in the switches yet but i do plan on it and i really didn't go into the door. I wired the wires for the mirror up to the dimming switch control like the post that i read said to, and the got the power for the mirror from my cigarette lighter, so that it will only come on when the ignition is turned on. The closest i came to the door was running my wires behind the dash from my a-pillar and the across under the steering wheel. I did have a problem like this when i put in my chrome door handles but that was because i had forgot to plug the other window control plugs back into the master switch on the drivers door
Old Jan 25, 2006 | 05:38 PM
njmodi's Avatar
Do I get a tax break?
Have you accidentally pressed the "window lock-out" button on the drivers side... thats my bet
Old Jan 25, 2006 | 06:03 PM
and we have the answer to my problem. sometime the hardest problems have the simpleest answers. I just came in from my car to look at the thread and write that I was an idiot and overlooked the most probable cause but someone else already stated it (only in a much nicer way) thank you njmodi. I should have checked this first but just didn't think of it my problems are solved and now i can start thinking of my next mod. Thank you all that tried to help and thank you for thinking of an obvious solution njmodi.
Thanks BK
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Tha'-Max
Aug 30, 2015 01:14 AM
kirkhilles
Aug 8, 2015 10:53 AM
