Ects
Old Jan 27, 2006 | 12:02 PM
Jamaha80
Ects
Does anyone know if the battery has to be disconnected to replace the etcs? Will the cel go off once i replace the bad part or do i need to reset it? Thanks.
Old Jan 27, 2006 | 12:06 PM
njmodi's Avatar
Do I get a tax break?
No, No (eventually, yes), Yes you need to reset it.
PAREDLINE's Avatar
It may go off. You should reset it. You SHOULD always disconnect the battery when you work with anything electronic. Must you? Probably not. Should you? yes
Old Jan 27, 2006 | 12:12 PM
Jamaha80
Thanks.. The only codes i had were for the knock sensor and ects which i know the ks code doesnt trigger the cel. I did the ks last night andill do the ects tonight. Does a bad ects make the engine perform bad? I assume it does. So far the KS has helped a lot in low end livelyness and has made an improvment. It also seems to have taken away the rough idle.
sake1bs
Sep 19, 2015 09:32 PM
maxinout93
Aug 20, 2015 02:17 AM
MikesChevelle
Aug 7, 2015 05:57 PM
Craig Mack
Nov 24, 2001 01:37 AM
nizmolee
Jul 14, 2001 06:32 PM
