OEM Foglight replacement
Is it possible/easy to install aftermarket foglights into the OEM foglight brackets that are arleady there?
I need to replace my cracked foglights and was wondering if i can do that, also can I use the OEM wiring to connect the aftermarket foglights with?
Has anyone done this or has any writeup on it?
thanks,
Ken
thanks,
Ken
fog lights come with brackets, youll prolly need to remove your stock brackets. if you get aftermarket fogs that are H3, they will work fine with your stock wiring. just make sure theyre 55w so you dont fry anything.
i recommended getting bosch compact 100. email daniel stern (www.danielsternlighting.com), he can send you a spec sheet with a picture of the beam pattern, and you can buy them from his as well. they are $57 each
something you may or may not like: the lenses are yellow, so that the light that is cast on the road is "selective-yellow" (theres a page of info on danielsternlighting, the fogs will appear lexus IS yellow, but will also appear yellow in the day, as opposed to yellow bulbs, or yellow capsules in the stock fogs
vingodine
45
05-21-2016 12:46 PM
