Installing eibachs/GR2's on my 95 max
Feb 12, 2006 | 09:35 AM
how much do i cut the dustboots on top to avoid banging??
thanks.
Feb 12, 2006 | 09:56 AM
Did your springs not come with a sheet that instructs you on how much you should cut them?
I believe half and inch is how much, but I'm not sure.
Feb 12, 2006 | 01:32 PM
Cut at least one ring off.
Eibach + GR2 = Very harsh ride.
Be ready for it, and make sure you get the alignment reset when your done.
Feb 12, 2006 | 02:14 PM
yea luckilly im aware of the ride..friend of mine has the same setup and he took me for a spin in it before i made my decision..ill check the instructions..thanks guys
Feb 13, 2006 | 01:34 PM
Definately on the alignment with the springs.
Feb 13, 2006 | 06:30 PM
don't do it!
Feb 13, 2006 | 06:54 PM
full compress the sturt....measure the remaining shaft... them measure the bumpstop then subtract..thats how much u need to cut
Feb 13, 2006 | 08:10 PM
The standard rule is 1/2"
Feb 13, 2006 | 08:50 PM
hmm i need new suspension what do youi mean by harsh im looking for a very stiff ride waht do yall recommend i have a 95 se
Feb 13, 2006 | 09:20 PM
some use the word harsh in place of stiff. If someone cant deal with a ride thats too stiff they call it harsh.
Harsh would have you bouncing all over the place, or the car feeling like its going to fall apart when you go over bumps.
Feb 13, 2006 | 09:22 PM
people say the gr2s are too stiff... but mine were never stiff enough... it bottoms out too easilly for me. I hate gritting my teeth every time I come to a large bump hoping it's not gonna hurt. I'm not sure if it was as bad when i got them, but it was never great and I have only had them for less than a year... I wish i had gotten illuminas. Just my words on it... do what you want.
Feb 14, 2006 | 05:27 AM
.... bottom out..? no .... way... ur must be bad... they just dont provide movement... specially with lowering springs.. if u live in an area like Houston TX... while i was visiting my cousins i noticed the roads were even.. so if no bumps and holes in ur area.. then its alrite bearable.. but in NYC... forget it... YOU SCREWEED.... im getting illuminas with the tax refund...
Feb 14, 2006 | 05:30 AM
ok so what do yall recommend i want something that grips like a mother but as you say isnt too harsh and i dont want something that will rip all my money away from me
Feb 14, 2006 | 06:00 AM
are you suppose to cut the bumpstop? i didnt and mine rides fine.
Feb 14, 2006 | 06:03 AM
Quote: .... bottom out..? no .... way... ur must be bad... they just dont provide movement... specially with lowering springs.. if u live in an area like Houston TX... while i was visiting my cousins i noticed the roads were even.. so if no bumps and holes in ur area.. then its alrite bearable.. but in NYC... forget it... YOU SCREWEED.... im getting illuminas with the tax refund...
You might want to switch to H & R's too. Eibachs are very very stiff.
