Cleaning Fuel Injectors
Old Feb 17, 2006 | 06:29 AM
Juicey's Avatar
This ORG has saved me $$$$$$$$
No trying to be a thread *****. Can people give me some pro's and con's to having my fuel injectors cleaned by a mechanic (like Grease Monkey).
I know it's good to get transmission flushes and radiator flushes etc but I'm concerned about stories of all kinds of black smoke coming out of the car during these "cleanings". Is this stuff burning off and to burn off is it travelling into places that can be damanged?
Old Feb 17, 2006 | 06:45 AM
renatonetmail
By a maechanic? I personally wouldnt do it unless there is a very strong reason as of why.
Chevron-Techron on almost empty tank. <-- That's all i could say.
Old Feb 17, 2006 | 09:45 AM
Juicey's Avatar
So Techron actually does what it says huh? My car just isn't as responsive as it such be. I want more acceleration for only a little push on the gas but instead I have to put my foot 1/2 inch down to get any kind of resonable acceleration.
I'm just looking into the fuel system first before I consider the KS. I've replaced the fuel filter and I don't see a need to replace the fuel pump unless I have trouble with it. Therefore my next step is the fuel injectors since I'm not having any problems with sensors.
Old Feb 17, 2006 | 11:17 AM
cefiro8701's Avatar
try getting a new airfilter before you go for a fuel injection cleaning.
use ZAK fuel injection cleaner if you do decide to do it.
Old Feb 17, 2006 | 11:31 AM
Juicey's Avatar
I have a k&N air filter which I just cleaned a week or so ago. Also have tried fuel injector cleaner already. I use 93 octane gas.
Old Feb 24, 2006 | 03:04 PM
Russian019's Avatar
I work for a Porsche race shop in Virgina and we flow test and service injectors all the time. More than half the time, we find at least one bad injector. What happens fairly often is that the solenoid in the injector goes bad and as a result, will dump more fuel than it's supposed to. We've seen cars get better throttle response, a little bit of power, and even cleaner emissions after an injector service. What is your mechanic charging you for this?
Old Feb 24, 2006 | 03:46 PM
Maximus_95's Avatar
huhmm.....im also wondering how much a injector cleaning service would cost. i should clean mine out.
Old Feb 24, 2006 | 09:10 PM
Russian019's Avatar
We generally charge an hour to remove and $20 an injector to flow test, clean, and install new o-rings, caps and filter baskets.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
gustavison
Oct 4, 2015 06:50 PM
msellas
Sep 23, 2015 09:16 PM
bumpypickle
Sep 20, 2015 08:22 AM
