Popping Noise from Left front....hard steering
replaced my CV boots...3 months ago...all is well, recently have had a loud popping noise come from the left front when i steer to either extreme. checked the joints, the boot, and the power steering arms...all seem alright...any suggestions??
Originally Posted by Fr33way
Are you on stock springs? Strut bearing would be something to check.
If you changed your springs, I'd check the clocking of the upper spring perch as well. I see so many Maxima's with incorrectly clocked upper perches after a drop it's not even funny. And they all wonder why their suspension makes noises.
I have had the same problem with my 95 SE and changed out my wheel bearings and it fixed the problem. What mishmosh said is true also if your CV boots were torn and water and dirt and grime gets in there it can get to those links. And if you don't catch it it will seep into the steering rack. Good Luck
BrandonCause
Sep 14, 2015 10:41 PM
ballerchris510
Sep 11, 2015 05:29 PM
