Oil on Spark plug....
So i was changing my plugs today, and noticed that on the #1 plug (rear/far left) there was clearly oil. It wasnt old caked on oil, it was fresh and still viscous. 5 of the plugs looked like this
But the one I'm describing looked like this
Now i know it happened because a seal somewhere is screwed.... but is there a way to test it? Thanks in advance for any suggestions!
A compression test is your best bet for testing it otherwise you would have to pull the valve stem out and visually inspect. If your pursuing that method it makes more sense just to replace it as this is a very labor intensive job.
I have had the same problem only in the summer it happens. My rear middle spark plug will stop firing for some reason and car will sound like a Harley or sumthin and i get gas in my oil. Sounds like some serious work wherever it is.
this is common on the #1 plug. although I have not found a plausible explanation yet. in my case, it is not the valve cover seals, piston rings, or head gasket (I have no oil in the spark plug tube, and my compression is great on all cylinders, and I have no discernable oil consumption). check these things on your car - if they are all ok then don't worry about it.
I'll try to find an old post with my results...
Well I just got in from pulling the plug, and there is not a trace of oil... So im guessing it happened in the 75000 miles the old ones were on, which i believe, because my dad didnt understand the word maintainance....
Same here. It feels fine to me. If it throws a CEL or starts shaking violently ill do something
05RLS2
Apr 14, 2016 11:49 AM
Need help
23
Oct 2, 2015 08:56 AM
