safe jacking point
Old Feb 25, 2006 | 12:46 PM
joew's Avatar
safe jacking point
there are 4 areas for you us to jack our car. the front are bent from auto shop from a few year back. what other area where is safe to jack up the car with a 3 ton jack?
Old Feb 25, 2006 | 01:52 PM
Trajiksmax's Avatar
Proud Maxima Owner
When using a floor jack, for the front use the skid plate. You will see this run down the middle of the car. For the rear use the axle beam that runs from wheel to wheel.
Old Feb 25, 2006 | 02:12 PM
nismos14's Avatar
§è~® f®ÈÄk
You can't jack it up now, ever again!1!111!!
Old Feb 25, 2006 | 08:34 PM
joew's Avatar
where do you put your jack stands for the front and back?
Old Feb 25, 2006 | 08:35 PM
joew's Avatar
what do you mean? you mean don't use the damage area right?
Old Feb 26, 2006 | 01:38 PM
Tim96I30t's Avatar
On the front underneath the middle on the front of the crossmember there is a bump, that is where you place the jack. In the rear end use the beam that rums wheel to wheel, there is a spot there as well just don't pinch anything when lifting up. Hope that helps, front crossmember and rear beam both in the marked spots, you can see them.
Old Feb 26, 2006 | 06:24 PM
joew's Avatar
thanks buddy.
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
sliptap
Sep 30, 2015 05:57 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
