Stupid EVAP
Old Mar 1, 2006 | 12:31 PM
StillenIsaJoke's Avatar
Stupid EVAP
Got DTC 0705 & 0903 says its something with the EVAP systems any ideas on whats wrong with it?
Old Mar 1, 2006 | 01:04 PM
Trajiksmax's Avatar
Proud Maxima Owner
0705: EVAP System leak
0903:EVAP Canister vent control valve circuit fault
I would go through and check to make sure there is no loose hoses. Also check all electrical harnesses make sure they have a good connection.
Old Mar 1, 2006 | 01:18 PM
MaximaSpd85's Avatar
just got rid of mine last week for good!! u need to buy the carbon cannister (i think thats the name) with the valve connected to it. Its the gray box near your left rear tire. i found mine at a junk yard last week, took a chance on it working, and raplaced the old with the junkyard one, no more codes!!
Old Mar 1, 2006 | 01:20 PM
Fork's Avatar
Maximaler Experte
Inside the canister is a valve - it sometimes get stuck. Take it apart, take out the EAV valve, spray it with WD-40, make sure it's not stuck, put it back in. Clear codes, and presto, it's all goooooood.
Old Mar 1, 2006 | 05:25 PM
Just went out and lubed up the EAV valve, see what happens, thanks
Old Mar 1, 2006 | 05:30 PM
konak85's Avatar
was that for 0903?
Old Mar 1, 2006 | 06:39 PM
maxfanfromohio's Avatar
Shiver me timbers.
I had 0705 and I just replaced the valve. I tried the wd-40 trick, but it wouldn't budge. I had my CEL on for like 3 years and just now decided to go ahead and fix it. It was like $90? at the dealership. It cleared the code.
Old Mar 1, 2006 | 06:47 PM
Yeah I have a feeling my valve is shot. I was able to free the flang inside with wd-40 and move back and fourth (have to wait and see). yeah 90 bucks for a new one thats lame.
Old Mar 1, 2006 | 06:58 PM
I have a question about how the valve is supposed to be when you take it of. When I took it off the plunger was extended out or open. I pushed it down a couple of times to work in the wd-40 and it was poping back open easier each time I did it. Is it supposed to be open when you take it off? Doesn't it close electricly?
Old Mar 1, 2006 | 07:16 PM
Shiver me timbers.
I have no idea. I didn't look very closely at the new one. I just took the old one off and replaced it. Sorry.
Old Mar 2, 2006 | 04:07 PM
After taking the canister out and lubing the valve up, I managed to get rid of the 0705 DTC but 0903 comes right back up right when I start my car. Before I could clear the code for like 5 days. Now 0903 puts up right after I clear it. I'm thinking the Vacuum Valve is shot electricly.
tseng1023
Oct 15, 2015 08:30 AM
homeofbacon
Sep 23, 2015 07:17 PM
pears
Sep 18, 2015 05:25 AM
220k+ A32
Sep 11, 2015 02:18 AM
dcam0326
Sep 7, 2015 07:26 AM
