Help on Installing HID
Old Mar 4, 2006 | 03:27 PM
elgatomax's Avatar
I bought new HID for my max. The Installing is easy to install but im stuck on one thing. The Wires that comes from the HID are blue and brown. Then the wires from the stock are green, black and yellow from the left and black, blue, and green from the right side.
Now i got the HID to work with blue(HID) to black(stock) and Brown(HID) to green(stock)
But now the guestion is when i turn to HIGH beam it turns off WHY is that
Can anyone help me
THANKS
Old Mar 4, 2006 | 03:37 PM
98MaXeDouT's Avatar
Ok i think the same thing happened to me, did you have bi-xenon kit?
Old Mar 4, 2006 | 03:48 PM
happyricefob's Avatar
V^___^V
9004 hid kit only comes with low-beam. unless u buy the bi-xenon kit which comes with low and high beam
wikidminds's Avatar
coming from the car...are ur 3 wires. one is for low beam....one is ur high beam.....the other is ur ground wire.
if my sorry a$$ skills and memory serve me any good....i wud say that u have ur lights connected only to ur low beams. and ur high beam wire is just sitting doing nothing.
thats how my hids are set up. theyre only on when my low beams are on. once i click the headlight switch to high beams....the hids turn off cuz nothing is hooked up to the high beam wire.
i took my high beam wire and wrapped it in some electrical tape and tucked it away nicely.
thats how i did mine and i guess thats how i wud explain it. if anyone else has a better explanation....please correct me if im wrong.
V^___^V
btw mine only had two wires. red and black. red for 12v and black for ground.
Old Mar 4, 2006 | 03:55 PM
elgatomax's Avatar
i got xenon conversion kit
As for the 3 wires, i got two connected to the kit and one doing nothing. I did try hooking that one with one of the wires but nothing happen.
Is hard to tell which one is for cause from the ballast there is blue and brown
and then from the car there is green, black and yellow and then blue, black and green
it looks easy but then you get stuck on something
Old Mar 4, 2006 | 06:23 PM
Tatanko's Avatar
Bacon Lover
But is it a bi-xenon kit? We need to know that. Chances are if you don't know the answer to the question, then it isn't bi-xenon and your setup is wired correctly and you have no high beams because it's not bi-xenon.
Old Mar 4, 2006 | 06:29 PM
elgatomax's Avatar
i couldnt find anything that it would said it would be bi-xenon so i dont think it is
elgatomax's Avatar
so if i dont have no high beam so pretty much one wire is by it self
Old Mar 4, 2006 | 08:09 PM
Tatanko's Avatar
Bacon Lover
You bet.
10 things
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
