How to tighten up steering?
Old Mar 10, 2006 | 02:52 PM
95bluse's Avatar
Hi guys...mostly stock '95se 5spd here (just got a y-pipe -one mod at a time), and I'm wondering what's the best way to tighten up the steering? Car seems to want to wander at highway speeds, even after alignment, tires pressure adjustments etc. I heard that there are bushings I can change, but have no specifics. I'm hoping to get the suspension done later this spring.
Car has quite high mileage (270k miles). Appreciate your help.
Old Mar 10, 2006 | 03:18 PM
MDeezy's Avatar
change innner and outter tie rods would sharpen up the steering, in addition to new control arms, and new bushings.
Old Mar 10, 2006 | 03:58 PM
Kevlo911's Avatar
Kevlo for President
Or do what I am doing and replace the steering rack
Old Mar 10, 2006 | 04:00 PM
MDeezy's Avatar
damn what arent you replacing lately
Using a 99 steering rack?
Old Mar 10, 2006 | 04:03 PM
Kevlo911's Avatar
Kevlo for President
Yes sir, 99SE.
It's all part of the overhaul.
Old Mar 10, 2006 | 04:09 PM
pmohr's Avatar
No more Maximas...
What's the benefit of the '99 over any other year model 4th gen? Are you doing it just because it's newer, and should have less miles on it and less wear, or is there an actual change maybe in gearing or something?
Old Mar 10, 2006 | 04:11 PM
MDeezy's Avatar
99s had tighet steering, it wasnt as loose and "sloppy" as the previous years from the 99.
Old Mar 10, 2006 | 04:14 PM
pmohr's Avatar
No more Maximas...
Really? Huh, learn something new every day. Never seen that posted around here before, or listed in model year changes.
Is it worth it to change it out (gains vs parts/labor)? How much of a difference is it?
Old Mar 10, 2006 | 04:25 PM
dgeesaman's Avatar
Maintenance Monster
Changing a rack is a lot in labor, parts cost isn't bad if you find a used one. (I found plenty on that internet junkyard parts search site).
The possible reasons for loose steering are numerous:
1) Loosened steering rack (can be retightened)
2) Worn rack bushings, or loose rack brackets
3) Worn/loose inner tie rod
4) Worn/loose outer tie rod
5) Bad balljoint
6) Worn control arm bushings
7) Poor spring/shock choice
8) Poor tire choice/inflation
I've done nearly all of them in pursuit of my loose steering problem. The sensible thing to do is inspect those items I listed and change only what is worn. See if you can find an ****-retentive mechanic (most aren't, even good mechanics) who will use a fine-toothed comb to find the problem.
Dave
Old Mar 10, 2006 | 05:17 PM
njmaxseltd's Avatar
Buy a 99, problem solved.
Old Mar 10, 2006 | 05:21 PM
incognito903's Avatar
good thread man i was wondering about this yesterday, driving 75mph and twisting the wheel back and forth like 1/8 of a turn each direction without the car changing course at all
Old Mar 10, 2006 | 06:10 PM
95bluse's Avatar
5) Bad balljoint
Dave
All good points, the only thing I've done so far is replace the ball joints, my mechanic noticed some play in them. I really know what you mean about mechanics, most rarely have the patience to take a look at this stuff. I hate being brushed off when they mention the age of the car. I'll try to look for someone knowledgeable about front-ends, I just don't want to pay an arm and leg.
Appreciate the input guys, keep it coming!
Old Mar 10, 2006 | 06:12 PM
95bluse's Avatar
I heard about this swap, but the labour alone is freaky. I also heard of some steering pre-load adjustments that can be done also. However, I'd like to try the easy/cheap methods as a first stab at the issue.
Old Mar 11, 2006 | 07:47 AM
BEJAY1's Avatar
Conecarver
Have you tried poly FSB bushings and zero front toe vs toe-in yet? Maybe a power steering flush if you've never had one recently.
Old Mar 11, 2006 | 09:48 AM
95bluse's Avatar
I'll take a look around here in Toronto for the poly bushings. I guess the zero toe vs toe-in should be done during alignment? I'll have a talk with the shop about this when I go in.
Power steering has never been flushed, just topped up occasionally. Maybe it's worth a shot.
Thx
Old Mar 11, 2006 | 10:09 AM
Fr33way™'s Avatar
Wild for Width
It's not only '99 is it? My 98 has alot more feel and feedback than any 95-96 I have ever driven (drive them quite often). Didn't some form of the I30 also have a desirable rack?
Old Mar 11, 2006 | 11:46 AM
AMG NMY's Avatar
seems like a lot of modifications are needed
Old Mar 11, 2006 | 10:02 PM
dko's Avatar
dko
duck and cover
i've heard good things about matt blehm's lower tie bar (LTB)
Old Mar 13, 2006 | 09:01 AM
devilz05's Avatar
Shift_3.0
Get an RSB, it gets rid of "some" pesky body roll and all of the 'Oh my god my car is floating in an ocean' feeling during high speed lane changes. IDK why Nissan didnt include a serious RSB bar in SE models, it seems like a logical move to me.
Old Mar 13, 2006 | 09:24 AM
MaximaSE96's Avatar
Maxima Owner
word...my steerinf feel in my 98 is much better than my 96......but repalce all frotn end parts....a nice set of performance springs alway helps...
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Noela
Sep 26, 2015 08:22 AM
