Intermittent 'cold' starting
Old Mar 11, 2006 | 01:19 AM
smaye's Avatar
I mentioned this in someone else's post, but it seemed off-topic.
I have a 1999 Maxima with 113,000 miles. With the exception of a bad O2 sensor we have never had any probalems out of it.
Recently it would not start. The starter turned over and over, but made no hint of starting. The car was in the middle of a parking lot and I needed to get it home. It may be wrong, but I sprayed some starter/cleaner in the plenum. It kicked off and ran.
Over the last month the car failed to start 3 or 4 more times. Each time playing with the gas pedal position seemed to help get it going.
I read several posts about cleaning the plenum. I will do this today. The plugs are new, so I don't think this is the problem. I may be wrong, but those times it is having troubles starting and we finally get it going the exhaust fumes smell as if the fuel mixture was very rich.
I also read the sticky on TSBs. One mentioned POS not 180. How do I get the 'POS count'?
Another says Start Signal stays "OFF". How can I tell what state the start signal is in?
Anyone had this problem before. Any help would be appreciated.
Old Mar 11, 2006 | 04:23 AM
njmaxseltd's Avatar
Check both crank position sensors.
Buy a Haynes shop manual best 15 bucks you'll ever spend on your car.
Old Mar 12, 2006 | 03:56 AM
smaye's Avatar
Looking at the factory manual I only see one crankshaft postioning sensor down near the oil pan.
Did I miss one?
Old Mar 12, 2006 | 07:37 AM
njmaxseltd's Avatar
There are two crank position snesors, REF and POS.
REF is located on the crank pully and POS is under the car on the transmission bell housing, it looks at the flywheel. You can check them with an ohm meter.
Ignition switches are also a common failure with similar symptoms.
Old Mar 13, 2006 | 12:45 AM
smaye's Avatar
Yep. I missed that one. I also see the troubleshooting info, too. The REF and POS sensors show I can troubleshoot with the on-board diagnostics with either code 0407 (REF) or 0802 (POS).
If these codes are not present is it safe to assume this is not the problem?
Also- While cleaning the plenum I noticed what looked like resistance wires in the airstream between the air filter and plenum. I cleaned these, too. It appears to be going to the attached wire harness plug. What sensor is this?
Smackasmith
Feb 1, 2016 12:40 AM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
tardrex
Sep 11, 2015 07:35 PM
trungg86
Sep 4, 2015 04:58 AM
