How much for a good suspension setup??
Old Mar 13, 2006 | 04:40 PM
  #41
Fr33way™'s Avatar
Wild for Width
Originally Posted by evil_spork
how stiff of a ride will coilovers be?!
From going to GLE setup to full coilovers?
At first it will seem unreasonable, but the ride is not bad at all when properly adjusted.
Old Mar 13, 2006 | 04:41 PM
  #42
evil_spork's Avatar
Originally Posted by Fr33way
If you get like a few of us on this board you may want to spring for the lifetime alignment. After doing axles/balljoints/entire suspension swaps it has actually been SAVED me money.
Spring and strut setups are alright for a mild street setup but the springrates and aggressive dampening of true coilovers (a past set of D2 Racing Sport for me) cannot be matched and you wont beleive the potential of the A32.
For me, the constant maint. and trouble shooting (noise only) were the downsides of having the D2 coilovers. Coming up on the winter time and a heavy school/work load I did not want to spend time troubleshooting suspension problems.
If I had a full stock suspension laying around (I sold my GR-2 struts and was only left with SE springs) it may have been a different story. I more than likely would have just pulled the D2s for the winter and taken my time to fully service them.
I ended up trading the set of D2s for Tein S-Tech paired with AGX + a full stock suspension. From a pure money standpoint I would seem on the bottom but I have not regretted it in the slightest. I have played with the AGX's a bit and gotten the handling (not a strongpoint in the S-Tech) a bit sharper by also swapping bushings all around.
This will not be my last setup but I am happy with it for street driving. When the time comes I will more than likely go with a newer (mine were from the original batch) set of D2's as I am still keeping an eye on how the K-Sports have been holding up for people on the board.
to sum it up... coilovers are awesome?
how harsh is the ride? am i going to be rattling fillings or just feel all the bumps?
can you give more feedback to the comfort and performance of your spring/strut vs coilover experience please.
yeah im prepared for it to be a very harsh differance. but if my moms A6 is any indication, then i know thats the ride i want.
the idea is if i can have people ride in the car and have it feel sporty and like its a performance car vs a harsh unpleasant ride will be (somewhat) key to my choice.
ive ridden in a friends benz sl500, g35 sedan, and e320 before. the benz had a very hard setup, you felt big bumps, smaller ones melted away though.(the MB cars are early 90s, the g35 is an 04)
Old Mar 13, 2006 | 04:56 PM
  #43
Mxrider52's Avatar
I support for what?
Your gonna feel about every little imperfection in the road.
How do you guys tell when your rear end is gonna come out with the RSB on? I havent had it happen yet but I wanna kind of expect it if it does happen.
Old Mar 13, 2006 | 05:04 PM
  #44
evil_spork's Avatar
you dont.
thats the problem, it gives pretty much no warning before it breaks loose. without the rsb youll get alot of warning(tire squeel, ect)
Old Mar 13, 2006 | 06:38 PM
  #45
RA030726's Avatar
I'm nutty for Nissans
going from 225/50/16 to 235/40/18 makes a huge difference in response and gets rid of that wallow feeling on the highway. the ride is only marginally worse, nothing to complain about.
stock SE springs are about 2.1f/3.6r kg/mm
eibach springs are about 3-5/3-6 (stiffest drop spring)
compare those with tein 7/6, Boss Chen 7/8, JIC 9/6, D2 9/7, Ksport 9/6 (all rates can be changed)
Old Mar 13, 2006 | 07:55 PM
  #46
wootwoot's Avatar
Originally Posted by JSutter
let me redo my list for a daily driver:
FSTB
RSTB
Eibach springs with your choice of adjustable strut
Long travel rear mounts
17x8 w/ 235/45 summer tires
ES bushings
Well this looks like the list I will be going with. I am going to be using the car as a daily driver but with some aggresive tendencies. I live in Phoenix so I will probly use the same tires year round. Now only 1 problem, I gotta buy me a max
Old Mar 13, 2006 | 08:07 PM
  #47
Fr33way™'s Avatar
Wild for Width
Typo? BTW does anyone besides 1FSTMAX have or know anything about the BC coilovers?
Old Mar 13, 2006 | 08:08 PM
  #48
VIP Maxima
check 5th gen forums, there is a thread about BC's
ps. the stiffer the springs the better. trust me, you will REALLLYYY thank me once a chick with DD's sits up front
Old Mar 13, 2006 | 08:11 PM
  #49
Fr33way™'s Avatar
Wild for Width
The good news is the GXE vs. SE suspension is a non-issue for you because you are going to rip it out anyway. Hymm now. . . .lightweight GXE or optioned SE is the question. . .
Old Mar 13, 2006 | 08:12 PM
  #50
Fr33way™'s Avatar
Wild for Width
Thanks, I don't go in there very often.
Old Mar 13, 2006 | 08:15 PM
  #51
95 maxima se's Avatar
Silver Tooth S2K 9k FTMFW
now tht were talking about combos, im gonna install my ksport springs. was wondering if i should buy kyb gr2's or tokico hp's?? and wat else was needed??
Old Mar 13, 2006 | 08:56 PM
  #52
Fr33way™'s Avatar
Wild for Width
Is the drop with the K-Sport spring around 2.2F 2.0R?
That may be a bit much for the GR-2s.
Old Mar 13, 2006 | 10:21 PM
  #53
evil_spork's Avatar
im actually going from 195/65-15's to likely 245/45/17s. so it will be an even bigger jump for me.. and GLE suspention!
now if i go coilover.. ksport or d2? seen alot of good about both. but whats best?
Old Mar 14, 2006 | 04:25 AM
  #54
RA030726's Avatar
i think i got the spring rates correct, but i could have had them mixed up.
the gle.gxe share the same front springs as an se. the rear springs on the se are slightly stiffer, along with stiffer valved struts. also the se has some poly bushings in the front suspension. thats it.
195/65/15 is not stock, stock is 205/65/15 on the gxe. you will feel a huge difference in ride, traction, handling with going up to the 17.
ksport and d2 are basically the same, so pick your color.
any drop spring limits wheel travel, so if all you care about is looks, then get something lower than 1.5". but if you want to handle then stick with a mild drop and a stiffer spring. better yet shorten some koni inserts and run rear mounts to help add some suspension travel.
Matt93SE
May 24, 2019 02:58 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
pkfinn
Jan 3, 2016 02:55 PM
Chef N
Sep 22, 2015 11:20 PM
95Maxi
35
Sep 2, 2015 10:37 AM
