WTF, Car OVERHEATING! NEED HELP!!!!!!
Old Mar 12, 2006 | 03:13 PM
khantalha+'s Avatar
PLZZZ HELP!!
I posted one thread about my car overheating last week. So here i go again;
i changed my temperature sending sensor and got the same temperature as i had with my old one. now what i think the problem is the new thermostat i got is bad or some thing, because the upper radiator hose is warm as hell and the lower one right before the thermostat is cold as it is. The new thermostat i got was from autozone and i bought it last week, but when my mechanic changed it he said the new thermostat is not openning and the car is over heating. After driving my car 2-3 miles under 50mph, then it starts to overheat. I dont have a leak in radiator or in water pump and my coolant level is where it should be, and i even ran my rad. fans manually but it didnot make any difference. SO ANY IDEA WHAT COULD IT BE??????
Old Mar 12, 2006 | 10:02 PM
darklegend06's Avatar
If you changed your thermostat and still over heating, you might have a problem with the water pump. The pump or the belt to drive it might be bad. just a thought.
Old Mar 12, 2006 | 10:14 PM
NmexMAX's Avatar
dot dot dot ...
It's run off the timing chain.
Ding ding ding we have a winner.
Old Mar 13, 2006 | 05:49 AM
mindlessoath's Avatar
if anyone is overheating then it could be...
radiator (could be clogged (internaly or externaly (front or rear))).
waterpump
thermostat
hoses
fans (not spinning at correct speed or not spinning at all).
sensors are also a possiblitiy, but not likly depending on the above.
Old Mar 13, 2006 | 05:01 PM
khantalha+'s Avatar
Another problem is my fans dont even run, i have to run them manually by taking that switch off of that coolant temperature sensor. I thought my sensor was bad so i even bought a new coolant sensor, and a new temperature sending sensor but that didnot make any difference. is there any thing else to check for the fans besides that thermostat.
Old Mar 13, 2006 | 05:45 PM
njmaxseltd's Avatar
Was the system bleed correctly? Run the car untill it's hot with the radaitor cap off, increasing RPM's until the fans turn on. That will assure all the air is out and the pump is circulating the coolant correctly.
You could also have a blown head gasket......
Old Mar 13, 2006 | 06:09 PM
pmohr's Avatar
No more Maximas...
If you turn the AC on, do either/both of the fans turn on?
Old Mar 13, 2006 | 06:13 PM
khantalha+'s Avatar
my head gasket is in great shape, and no my fans dont come on with tthe ac running.
Old Mar 13, 2006 | 06:15 PM
khantalha+'s Avatar
I will try this tonight.
thanks.
Old Mar 14, 2006 | 05:42 AM
cardana24's Avatar
Blown
I think either the thermostat is bad or you have air in the lines. Either one of these problems would cause the lower hose to be cold. The system could be air locked or the t-stat is not opening. Try what NJTom said, if that does not work then I would guess its your thermostat.
Old Mar 14, 2006 | 06:20 PM
khantalha+'s Avatar
I just bought a new tstat today. hopefully i ll change it tonight.
Thank you guys, i really appreciate your help.
Old Mar 16, 2006 | 12:19 PM
hasei's Avatar
日産
I have a friend who works for a company that manufactures all thermostats for our VQ engines. He said that a lot of aftermarket thermostats for VQ currently sold in the United States, including ones available at autozone, are made in China or some other Asian countries and their quality/design is seriously questionable. He also said that the one sold at thepartsbin.com is the one they manufactured.
If your issue turns out to be a thermostat, I suggest that you get an OEM one.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
Gsantos79
Aug 8, 2015 07:41 AM
