wheel bearing help....
hey guys i noticed that on my 99 i30 the pas. side wheel bearing needs to be replaced....now i have access to a shop press so i was thinking of removing the whole pass. side spindle press out the worn wheel bearing and press in the new one and im good to go...my question is when i went to the auto parts store to get a price quote the clerk asked me if i wanted the seal as well? so do i need to replace that as well? any info or tips would be greatly appreciated!
TIA
Greg
TIA
Greg
Front or rear?
I need to change the rear passenger side bearing (hub) tomorrow night on my '98. Can I get the old hub off myself by hand or with a crank pulley puller? Thanks in advance.
(Sorry, didn't want to threadjack, but I can't seem to start a new thread.)
front bearing will need to be pressed out. inner and out seal should have the same part number.
rear wheel bearing comes with the hub assembly and you take the middle 30mm?? nut off. Easy.
I juss did front and rear on a customer's Maxima.
so i will need to get the inner and outer wheel bearing? i thought there was just one? ok its a good thing i asked you guys so i can be ready to tackle it, how long did it take from start to finish?
Im not sure if you can get the hub from Autozone. And yes, if you want to buy your parts from Autozone then just walk in and ask for them. If you can spring for the extra money I would get OEM parts for this. Its not something you would want to do again because of a cheap bearing. I just bought the hub, bearing, and seals from Dave Brunett @ South Point Nissan in Austin for $206.
londonflu
40
Sep 25, 2015 09:11 AM
