3rd Cylinder Misfire Question
Old Mar 19, 2006 | 09:28 AM
SLVR99MAXSE's Avatar
Anyone else who had the code for cylinder 3 misfire, what corrected it? I replaced the spark plug, but it is still misfiring. The way it misses is down in the lower RPMs, but I cruised on the highway at 3k with no problem unless I tried to accelerate. Does it sound like an injector or a coil pack? Please let me know if you have experience like this. I appreciate any feedback. Thanks.
Old Mar 19, 2006 | 09:53 AM
WielkiWaac's Avatar
MaximaDriver
check both: injector and coil
Old Mar 19, 2006 | 11:02 AM
Maxima880's Avatar
You could swap your coil with another cylinder on the same bank, clear the codes from the ECU, drive it around, then see if the code shows up for the other cylinder or for the same cylinder. Ought to help you narrow it down.
Old Mar 19, 2006 | 03:16 PM
njmaxseltd's Avatar
99's are prone to coil pack failures.
Replace the coil pack on cylinder #3 and your misfire will go away.
Old Mar 19, 2006 | 04:02 PM
Thanks. I will do that because I'm sure it has to be cheaper than replacing a fuel injector.
Old Mar 20, 2006 | 07:04 AM
That did it. Thanks!!!
Old Apr 17, 2006 | 05:42 PM
docroadrage's Avatar
Number 5 bank goes out often too... I had #3, then 5... There was a design problem with the original ignition coils. Also if you have more difficulty in the future check the knock sensor
James92SE
142
Jan 2, 2024 09:23 AM
ef9
Sep 29, 2015 11:29 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
pears
Sep 18, 2015 05:25 AM
